Author Topic: Good rebuild kit for Holley carb  (Read 4648 times)
winr1
« on: December 03, 2019, 10:32:09 PM »
9843-1  1710
I posted here a long time ago on kits but cant find the post
I liked the Quick Fuel kit but the bowl gaskets were hard plastic an leaked
Also, noticed some come with no sec. diaphram
Ricky.
« Last Edit: December 03, 2019, 10:37:58 PM by winr1 »
Re: Good rebuild kit for Holley carb
« Reply #1 on: December 04, 2019, 07:46:55 AM »
I use this kit:
Holley Carburetor Renew Kits 37-119.  It does not come with sec. diaphram, but when I refresh my 1850 carbs every few years, those don't have any issue so I don't need to replace them.
Summit has them for $28 right now.
« Reply #2 on: December 04, 2019, 09:00:58 AM »
Proform 67221
But it has the hard nylon bowl screw seals.
The kit I often use that had soft seals is Walker 159064. It doesn’t come with VS diaphragm
« Last Edit: December 04, 2019, 10:01:28 AM by Drew Pojedinec »
« Reply #3 on: December 04, 2019, 05:16:16 PM »
IMHO running Holleys for years - use only Genuine Holley kits and parts.  Note that QF is part of Holley now, so nearly same difference.  I only use the nylon bowl seals, never an issue.  Edelbrock kits are acceptable but I prefer Holley.  I don't care for the Proform kit gaskets, only use Holley blue parts.
« Reply #4 on: December 04, 2019, 05:58:57 PM »
The proform gaskets are identical to the Holley gaskets.
After getting a batch of 15 Trick kits with the needle orings dry rotted from sitting for a decade, I stopped believing the "holley is better" deal.
I totally 100% believe that was true years ago.
Just my personal experience.
« Reply #5 on: December 05, 2019, 10:01:06 AM »
I get it.  I still only get maybe 1/2 year out of Holley seat assemblies, umbrella pump check valves and diaphragms.  Even with race fuel in the car.  I keep the parts fresh in the methanol carb by hosing with WD-40 after every race.  Maybe have to start doing that with the gas carb.
The ProForm metering block gaskets I have used seem to be harder than the Holley parts.  I keep all my spare metering and fuel bowl gaskets in sealed bags, then handle only by the edges.
