Author Topic: c4 ford transmission plus water  (Read 6168 times)
390owner
« on: November 28, 2019, 07:46:22 PM »
I bought a 66 mustang with a rebuild c4. It was rebuild about 15 years ago. The car was driven very little then parked for the last couple of years. Any way some rain water got into it. When I pulled it today water came out of the tailshaft.  I would say about 1/2 a gallon. If I change the fluid and filter will it be ok?
winr1
Re: c4 ford transmission plus water
« Reply #1 on: November 28, 2019, 10:24:23 PM »
Have ya pulled the pan to see if there is any corrosion or such ??
Ricky.
« Reply #2 on: November 29, 2019, 01:22:14 AM »
This is the same car that had the 289 that was full of water? Was the hood off of the car? I don't see how that much water could get into a trans unless the hood was off and the dipstick was missing. I'm beginning to think the car was in a flood. With that much water in it, I'd think the valve body would be pretty much stuck and nothing would work or shift right.
Posi67
« Reply #3 on: November 29, 2019, 03:42:43 AM »
What Doug said...  Unless the dipstick was out and a large funnel was inserted into the tube I can't see how that much water could get into the trans. It's hooped and needs to come apart.
390owner
« Reply #4 on: November 29, 2019, 08:30:58 AM »
This is a parts car I bought. About 15 years ago this car was running and driving but not for long. I think it must have sat with the hood off. The dipstick was in the transmission but it was a cheap aftermarket. I will pull the pan tomorrow and see what it looks like and let you guys know
« Reply #5 on: November 29, 2019, 02:53:21 PM »
I also don't know how that much water could get in there.
How much money are you out if you change the fluid and filter?  That is the risk, plus your own labor and time.  Maybe you'll be presently surprised.
JMO,
paulie
« Reply #6 on: November 29, 2019, 04:43:51 PM »
Hopefully the Case is fine and the Pump is salvageable, otherwise it’s a parts transmission
390owner
« Reply #7 on: December 01, 2019, 08:30:59 PM »
I am . going to take the transmission to the shop here in town and let the guy tear it down and have a look The pan was nasty and the filter was too. So I will see what he says
« Reply #8 on: December 02, 2019, 09:38:00 AM »
Same as the others - it's going to need a look inside, sounds "not good".  Any corrosion or trash in the valve body will screw it up, and the valves in there are pretty sensitive to their environment.  Steels will rust, clutches will be damaged, etc.
shady
« Reply #9 on: December 02, 2019, 10:27:53 AM »
I'm a little more hopeful. The water will go to the bottom of the pan pushing the oil up, unless it had no oil in in it and gallons of water.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
gt350hr
« Reply #10 on: December 02, 2019, 12:06:01 PM »
  The valve body will be trash because the water will corrode the aluminum and stick the valves.
390owner
« Reply #11 on: December 02, 2019, 08:57:12 PM »
I dont know anything about an automatic. But I pulled the pan and the filter. Then the piece that the filter bolts too I removed. It had water and gunk in it. Is this the piece with the valves in it? It looked bad
« Reply #12 on: December 02, 2019, 10:47:11 PM »
Yes, the part that the filter attaches to is the valvebody that contains all the valves, checkballs etc. Like Chris said, they are very sensitive to any form of trash or debris or corrosion. Without seeing it, I would guess there's a 99% chance that the trans is only usable as a case core, at best.
390owner
« Reply #13 on: December 03, 2019, 06:34:18 AM »
Ok well I will go to plan B and use the other c4 I have Thanks for the replies
« Reply #14 on: December 03, 2019, 09:45:13 AM »
To make matters worse, C4 valve bodies are getting real scarce.  I would tear it down and try to save any hard parts that I could, including the case - IF your other trans is a similar model.  However, the pre-70 units are not as desirable as the post 70 units IMHO.
