Author Topic: 445 stroker kit  (Read 10098 times)
johnp427
445 stroker kit
« on: November 24, 2019, 10:13:42 PM »
new in box 445 stroker kit for 390 block
mahl coated pistons
file fit ring package
scat 9000 series crank
i beam rods
race main and rod bearings
all balancing done with mallory added
purchased from survival, never used
$2000 or reasonable offer
can deliver to columbus swap
call john 716 570 1880
Re: 445 stroker kit
« Reply #1 on: November 25, 2019, 07:22:50 AM »
John, do you have specs on the pistons?  1mm/2mm rings?  Dish or flat tops?  Are you willing to box it up and ship?
Thanks - Ross
johnp427
Re: 445 stroker kit
« Reply #2 on: November 27, 2019, 10:27:45 AM »
just seen your msg Ross, i will get ring info asap
johnp427
Re: 445 stroker kit
« Reply #3 on: November 27, 2019, 01:54:13 PM »
4.080 bore
1.0mm
1.0mm
2.0mm
steel,steel napier,std tension cp20
johnp427
Re: 445 stroker kit
« Reply #4 on: November 27, 2019, 01:55:34 PM »
flat tops with reliefs
rcianci
Re: 445 stroker kit
« Reply #5 on: December 08, 2019, 06:28:11 PM »
Do you still have the stroker kit?? What is the stroke?/ Thx. Bob.
c-reed
Re: 445 stroker kit
« Reply #6 on: December 09, 2019, 05:43:18 PM »
Bob, the 445 uses a 4.250 stroke crank. Hope this helps
johnp427
Re: 445 stroker kit
« Reply #7 on: December 11, 2019, 02:15:53 PM »
yes i still have stroker kit
Re: 445 stroker kit
« Reply #8 on: December 11, 2019, 10:15:04 PM »
Somebody should purchase this.  Scat is out of FE crankshafts yet again until after the first of the year.  I purchased the last five or six available out of the most recent run.  They only had 18 come in for the entire country, and eight or ten of them were already allocated to backorders when I called (one of my "six" was backordered through a warehouse that thought the had one...but they didn't).
johnp427
Re: 445 stroker kit
« Reply #9 on: December 18, 2019, 11:02:30 AM »
thanks Barry, if it doesnt sell i will just have to order new pistons from you for my sohc and use it in that
dsarge390
Re: 445 stroker kit
« Reply #10 on: January 15, 2020, 08:49:27 PM »
Hello, John. Is this still available?
edgarval
Re: 445 stroker kit
« Reply #11 on: February 12, 2020, 02:26:22 AM »
Still got it ?
