Author Topic: Scat crankshaft keyways  (Read 6818 times)
fairlaniac
« on: November 23, 2019, 03:52:40 PM »
Looks like Scat has different keys than OEM. Who sells the keys and do both or just one line up with the crank sprocket?
Thanks!
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Re: Scat crankshaft keyways
« Reply #1 on: November 23, 2019, 05:02:16 PM »
It's a SBC woodruff key.   One will catch the timing gear and the other will catch the balancer spacer.
TripleJ
« Reply #2 on: November 23, 2019, 07:05:12 PM »
I picked up two at the local hardware store. 3/16"x 3/4" if I remember right.
Joe Menard
fairlaniac
« Reply #3 on: November 23, 2019, 07:22:46 PM »
Will these work? This way I don't need the term SBC to enter my garage :)
https://www.mcmaster.com/98525a125
Doug Bender
1978 F150 2WD 390
CaptCobrajet
« Reply #4 on: November 23, 2019, 08:01:15 PM »
I use the BB Chevy key.  Probably the same as the SBC.
Blair Patrick
C6AE
« Reply #5 on: November 23, 2019, 09:07:02 PM »
I prefer the alloy keys, they are significantly stronger.
« Reply #6 on: November 24, 2019, 08:05:16 AM »
Pioneer PK9.  Only need the timing gear one.
It will grab a little of the damper spacer and the damper bolt torque is more than enough to keep that spacer from turning against the seal drag by a factor of about a billion...
« Last Edit: November 24, 2019, 08:07:59 AM by Barry_R »
« Reply #7 on: November 24, 2019, 09:23:29 PM »
No doubt you are right, but I can't stop myself from using both :)
