Author Topic: Cammer Vacuum Question  (Read 3084 times)
klassickars
« on: November 09, 2019, 09:26:28 AM »
I am building a Cammer and plan to use an early Ford C6 transmission but have no idea how much manifold vacuum to expect for the shift modulator.  I want to avoid a manual shift valve body.  Using Pond block and heads, 11:1 compression, Comp street lift cams, original single carb intake with Holley HP.  What kind of vacuum numbers are you Cammer folks seeing out of similar builds?  Phil
Re: Cammer Vacuum Question
« Reply #1 on: November 09, 2019, 09:58:14 AM »
What are the cam specs, and how many cubic inches?  That will play into the amount of vacuum you have.
klassickars
« Reply #2 on: November 10, 2019, 07:48:34 AM »
Looking for actual numbers from running engines.  Surely someone has hooked up a vacuum gauge to a Cammer.
« Reply #3 on: November 10, 2019, 07:56:41 AM »
You can make it whatever you need it to be.  It will all depend on the engine specs and cams that are ground for you.
Manifold vacuum literally depends on a plethora of specs.
