Author Topic: Lakewood bellhousing  (Read 5652 times)
Saltshaker
« on: November 02, 2019, 11:19:15 AM »
Does it need to be dialed in? Pull the motor, had Rob Mcqu down pins and 1 is now missing
Jon
C6AE
Re: Lakewood bellhousing
« Reply #1 on: November 02, 2019, 11:53:08 AM »
Absolutely, I have seen them as much as .020 out
Saltshaker
« Reply #2 on: November 02, 2019, 12:20:20 PM »
Anyone have contact number for Rob McQ?
Jon
Ranch
« Reply #3 on: November 03, 2019, 10:41:58 AM »
  These dowels work great, but you need to know which set you need depending on the run out of your Bell Housing  Getting the old ones out can be a different story, they are usually to hard to drill and Vice Grips didn't work and heat didn't help for me. I had to borrow a collet slide hammer set from my Machinist to pull them and even then they were tuff. So see if you can borrow that tool  before you go and deform them.
I needed to bring my old Lakewood in, it was out .015 TIR.
RobbMc Performance Products LLC,   775-885-7411
 robb@robbmcperformance.com
https://www.robbmcperformance.com/products/dowels.html
Dan859
« Reply #4 on: November 03, 2019, 12:54:26 PM »
Could someone please explain this to me?  I have absolutely no idea about this, so don't assume any baseline of knowledge
Thanks,
Dan
AlanCasida
« Reply #5 on: November 03, 2019, 03:02:07 PM »
I would check the mounting flanges too. Mine had so much paint on it that the transmission was not setting flat against the flange. I had to sand the paint off of both mounting surfaces to get it square.
C6AE
« Reply #6 on: November 03, 2019, 09:10:26 PM »
Thanks,
Dan
Aftermarket bell-housings are always suspect, but it is good practice to check the factory stuff also.
https://m.youtube.com/watch?v=fxNn4qk_KlM
Dan859
« Reply #7 on: November 04, 2019, 03:54:26 AM »
C6AE, thanks!
PaulProe
« Reply #8 on: November 04, 2019, 08:15:48 PM »
Along with dialing them in, make sure you take a look at the bell near each bolt hole. I found often the radius of the bend comes into play and when tightening the bolt, it tends to shift the bellhousing. I had to spotface a number of them on the last two I installed.
12 point capscrews help this a littlebit, but they too, can shift the bellhousing when tightened.
Just a heads up.
Paul
Ranch
« Reply #9 on: November 04, 2019, 08:32:11 PM »
 I didn't like the way Hex head bolt seated either and a wrench or socket didn't get in there to well either, so I used Allen Head cap screws.  They seat a lot better on the spot faces from Lakewood
