Author Topic: Mean Gene  (Read 2832 times)
chris401
Mean Gene
« on: October 30, 2019, 09:34:04 PM »
You said you had some Funk parts. This is the link I pm'd you.
http://fepower.net/simplemachinesforum/index.php?topic=7864.0
MeanGene
Re: Mean Gene
« Reply #1 on: October 31, 2019, 09:04:36 AM »
Hi Chris, the parts you need, I only have enough of for my tractor. I believe the hood is the standard one, length is made up with the adapter which you have. I do have a couple loaders, but way too far away, pretty sure you could find one locally, might have to lengthen the lower frame some to fit
chris401
Re: Mean Gene
« Reply #2 on: October 31, 2019, 10:52:31 AM »
The blade/plow that is on mine has a new brace/crossmember added about 6 inches behind the original rear mount. I was hoping you would say you had an extra intake system. Once I locate the correct or close enough air cleaner and duct work I will get a hood for it.
Thanks
