Author Topic: Reading spark plug colors  (Read 4510 times)
Dieselman966
« on: October 26, 2019, 09:25:53 PM »
I pulled some plugs today on my 352.  If I had to guess from what I've read they are running hot and lean.  Does any on here read plugs for tuning?
427mach1
Dieselman966
Re: Reading spark plug colors
« Reply #2 on: October 26, 2019, 11:08:33 PM »
What causes the red coating? Is that from the ethanol in the fuel?
GerryP
« Reply #3 on: October 27, 2019, 08:21:49 AM »
Red powdery looking coating is usually manganese.  You would find manganese is aftermarket fuel additives serving to raise octane.
« Reply #4 on: October 27, 2019, 10:37:58 AM »
Reading plugs is almost a waste of time if you are just swapping after running in a variety of conditions.  Load, mixture, timing, temperature, all is continuously changing.  If they are burning clean, and not melting/cooking the center, I'd just run them.
Knowing your mixture by reading plugs is really only effective after a WOT blast with an immediate shut down, and even if that is perfect, it won't look the same after driving around
Dieselman966
« Reply #5 on: October 27, 2019, 11:33:58 AM »
Ok I was mainly worried about the reddish color on them. I didn't know if that meant something. From what others have said that is just an additive in the fuel and nothing to worry about.
« Reply #6 on: October 28, 2019, 08:53:27 AM »
Also, unleaded fuel and high power ignitions tend to not color plugs like the "old days" of leaded fuel and points.  You can see color if running leaded race fuel, and you can get a reading on mix by looking into the header pipes - nice even gray color is a good sign.  Unleaded premium just soots everything up like cheap wood in a chimney.
