Author Topic: Spring Pressure for SFT Break In  (Read 3317 times)
66FAIRLANE
  • Andy
« on: October 24, 2019, 09:34:04 PM »
I will be using an old Crane Fireball 294 I used to run 20 years ago in a new build. I do not have matched lifters so will use new & follow normal cam break in procedures.
Is it worth swapping on some old worn out 80lb on the seat valve springs I have for this process or will 120 on the seat be fine?
Re: Spring Pressure for SFT Break In
« Reply #1 on: October 25, 2019, 12:48:06 AM »
I'll let the smarter guys chime in on answers, but I love that cam! I used one for almost 25 years in my Highboy. Very torquey and has a solid midrange. If I could find an NOS one, I'd grab it up in a second!
« Reply #2 on: October 25, 2019, 04:35:25 AM »
I aim for 100 lbs or less seat and under 300 lbs open.
« Reply #3 on: October 25, 2019, 07:44:30 AM »
I think the open pressure is what matters.  I don't think the seat pressure matters. I do agree that under 300 lbs is a good number for open pressure for flat tappet break in.
JMO,
paulie
66FAIRLANE
  • Andy
« Reply #4 on: October 26, 2019, 12:06:58 AM »
Thanks guys. Will check open & if over 300lb I will swap in the softies.
66FAIRLANE
  • Andy
« Reply #5 on: October 26, 2019, 12:09:22 AM »
I remember it ran pretty well all those years ago with a worn out engine, horrific exhaust manifolds & single pipe. Really interested to see how it goes with a fresh build & better bits & pieces.
