Member Projects
Mustang II frontend
Topic: Mustang II frontend (Read 6230 times)
Katz427
Sr. Member
Mustang II frontend
October 23, 2019, 12:46:47 PM »
I'm sure someone on this forum has installed a FE in a car with a Mustang II fro. Looking at a 55 Ford with a Fatman stub. Looks like I would have to mount the FE higher and slightly more forward, mainly because of the front steer rack and pinion. Any experience with this?
Re: Mustang II frontend
Reply #1 on:
October 23, 2019, 03:08:24 PM »
I don’t feel like my mustangs engine is farther up and forward. I did have to notch the oil pan for the tube connectors.
Here’s the thread you can get an idea. Lotsa weird stuff cause I was thinking out loud but you can get an idea where the engine ended up. Page three starts showing engine placement.
http://fepower.net/simplemachinesforum/index.php?topic=4267.0
62Falcon390
Jr. Member
Reply #2 on:
October 23, 2019, 04:22:50 PM »
im using a canton dual sump truck pan,, and placed my engine where it needed to be, and built mounts around it,, its a 62 falcon
Katz427
Sr. Member
Reply #3 on:
October 23, 2019, 06:22:08 PM »
Thank you! I read Marc's build again, and seeing that Canton makes a pan seems to fit well. The 55 Ford I looked at has a Fatman stub. The car was planned for a 302 but I would like to install an FE. Looks doable.
62Falcon390
Jr. Member
Reply #4 on:
October 23, 2019, 06:34:22 PM »
I have a build album of my MII on fb on the swap..
Reply #5 on:
October 23, 2019, 08:25:37 PM »
Tell you one thing I forgot to allow for is a windage tray. My engine as you can see is pretty tight to the cross member so it’s either gonna just barely fit or not fit. When I mocked it up it slipped my mind that I was going to use one. Oops. I’ll know soon as the engine is in the garage.
Administrator
Reply #6 on:
October 23, 2019, 08:35:22 PM »
I put an Art Morrison Mustang II style front clip in my 64 Galaxie. I did have to move the engine up a bit over the stock location, but if I recall correctly it was less than an inch. I fabricated a rear sump pan to fit, along with the motor mounts. No problems.
Dan859
Full Member
Reply #7 on:
October 24, 2019, 02:44:10 AM »
Hi,
I've got a Mustang II front end in my 64 Comet, with a 482 FE. The oil pan is a Canton FE Rear sump road race pan. If you're interested, I have quite a few pictures of the installation that I can send you, just PM me.
Dan
Member Projects
Mustang II frontend
