Author Topic: Jegs rocker arms  (Read 6011 times)
cattleFEeder
Jegs rocker arms
« on: October 22, 2019, 06:48:09 AM »
Never known these were available, I would rather use Brents rockers but an option if your on a budget.
https://www.jegs.com/i/JEGS/555/20199/10002/-1
Remember, RPM is your friend
cattleFEeder
Re: Jegs rocker arms
« Reply #2 on: October 22, 2019, 04:43:22 PM »
At that price you had to guess the big C was probably where they are made.
427mach1
« Reply #3 on: October 22, 2019, 07:54:33 PM »
I wouldn't use the stock-style adjustable rockers on anything other than a stock cam and springs.  If they are made in China, I wouldn't use them on anything, period.  I've broken too many (one) and learned my lesson!
« Reply #4 on: October 22, 2019, 08:57:14 PM »
I run stock adjustables with end stands. I certainly do not run a stock cam or springs.
« Reply #5 on: October 22, 2019, 11:43:15 PM »
I have also ran factory Ford adjustable iron rockers with Oregon Cams end support kit with .680" lift solid lifter cams, and I never broke a rocker arm. Without a valve end roller, larger cams can cause more side loading on the valve guides, but for moderate lift cams, not really a big concern.
