Author Topic: Who makes a high quality black distributor cap for early Fords now?  (Read 8173 times)
I was forced to run another color on the hyd roller 461, but hoping to find a high quality black small distributor cap.
NAPA, O'reilley, Advance, Autozone all have blue or gray brass terminals, or really cheesy black with aluminum.  Anyone know if a good black one is out there?
price5113
Re: Who makes a high quality black distributor cap for early Fords now?
« Reply #1 on: September 27, 2019, 06:32:07 AM »
#948220 Taylor is a nice quality cap, but is a "maroon" color. I believe a person could paint it if needed....................
« Reply #3 on: September 27, 2019, 09:27:37 AM »
If you want to run something like newer 8mm wires, you'll need an male terminal cap.  Either IH 304 V8 part.  Fits Prestolite/Autolite distributor base (same as Duraspark, etc.)
https://www.summitracing.com/parts/smp-al482
hwoods
« Reply #4 on: September 27, 2019, 09:37:38 AM »
Pertronix makes a stock look Ford Distributor,  may be able to purchase just cap from them/Summitt/Jegs
I have 10MM Taylor wires plugged into it
« Last Edit: September 27, 2019, 09:44:26 AM by hwoods »
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #5 on: September 27, 2019, 09:41:29 AM »
Ross, I’ve been using a lot of Standard Motor Products myself. JMHO
Wes Adams FORD428CJ
64 Falcon 428FE
wayne
« Reply #6 on: September 27, 2019, 03:53:59 PM »
rock auto as them
67428GT500
« Reply #7 on: September 27, 2019, 09:30:14 PM »
Standard motor products and NPD has a black one with the 1 on it that is concours and made by the OE manufacturer. It's got nice heavy contacts in it. The last Standard Ignition products cap I bought was light blue.
        -Keith
fairlanegt427
« Reply #8 on: September 30, 2019, 06:04:08 PM »
msd makes one.  i hate that red crap
67428GT500
« Reply #9 on: September 30, 2019, 08:02:17 PM »
This is what I bought.  High quality, brass contacts, gloss black and made in the USA.
https://www.summitracing.com/tx/parts/msd-5506
« Reply #10 on: October 01, 2019, 10:17:34 AM »
That's what I use on all my stock distributor stuff. Good quality and I haven't had any issues with them. I went that route because the last time I checked at my local Napa, I don't think they even offered the brass contact version anymore.
427HISS
« Reply #11 on: October 01, 2019, 05:17:24 PM »
Why not use black dielectric paint ?
67428GT500
« Reply #12 on: October 01, 2019, 10:22:07 PM »
I bought the concours offering from NPD. The notch always seemed excessively tight and I had to bump it down with my palm to seat it.
The carbon core " Marti Autoworks" concours reproductions pull apart and the red boots tear when they are removed from the plug. Even when I use dielectric grease inside the boot in small quantity.
I bought the MSD Street Fire wires and ran them. The issue is the straight boots are a little long and the two center plug wires touch at the end of the boots.
« Last Edit: October 02, 2019, 02:06:06 PM by 67428GT500 »
« Reply #13 on: October 02, 2019, 07:04:55 AM »
I bought the MSD Street Fire wires and ran them. The issue is the straight boots and a little long and the two center plug wires touch at the end of the boots.
I have seen issues with repop stuff, I ended up going MSD cap.  As far as the wires, I have ABSOLUTELY seen those Marti concours fall apart in my hands on a J-code 302 build.  Only good enough for non-running trailer queens IMHO (and I won't build those LOL)
I generally use the Taylor Spiro-pro black 8 mm when I am hiding on a stocker, then I have a small 5/16 Dremel bit that I open up the factory plastic looms and run them like Ford would.  Works well and they are all black and don't jump out at you and fit the modified looms
I don't even really consider that an option I'd entertain, not worth the time I'd have to charge to prep a cap.  Worse than that for me, one scratch away from those things we used to do as kids to scratch the black paint off of colored paper to make a picture in art class LOL
rcodecj
« Reply #14 on: October 02, 2019, 07:50:29 AM »
X2 on the Marti concours wires. I bought a set and they pulled apart before I got them on. They are not the same quality as what came on the car originally.
