Author Topic: My 2019 EMC engine Horsepower guess?  (Read 13954 times)
Re: My 2019 EMC engine Horsepower guess?
« Reply #15 on: October 08, 2019, 08:13:22 AM »
That's still cranking Joe ! Good job
« Reply #16 on: October 08, 2019, 08:24:23 AM »
Joe, I think I may have pinpointed a slight error in the EMC dyno test cell as well, not really confirmed yet. If the weather station was not placed inside the test cell in this situation, the weather data was incorrect. To get air exhausting through the room, you'll need a slight pressure drop of roughly 1". So hypothetically, on a 30" barometric pressure day, the dyno cell itself would be at 29" during a run. Plug that into the horsepower correction equation and the factor change is significant.
As was said on the other thread, all engines ran in this scenario, so all is fair. But this could be part of the explanation of being down some HP on their dyno.
Katz427
« Reply #17 on: October 08, 2019, 09:03:40 AM »
You are confusing air pressure in inches of water with barometric pressure which is given in inches of mercury. 1 inch of water is .0734 inches of mercury. The Dyno room there, is pretty accurate for  atmospheric corrections.
« Reply #18 on: October 08, 2019, 09:15:34 AM »
You don't want the weather cell in the room with the engine.  When the engine gets hot and the headers get hot, it makes the temperature go up in the room, which affects the correction factor.
« Reply #19 on: October 08, 2019, 09:19:07 AM »
The dyno room there had a very negative area above the carburetor.  You could see the air swirling above the top of the dyno cell, especially with those engines that had valve cover leaks and smoked.  The room was terrible hot this year, and the air exchange was brought in the front of the engine, and went out near the floor at the rear of the room, so no fresh air actually was circulating near the carburetor area.  At UNWO, they had air from outside the cell blowing directly on the carburetor area from a large flexible tubing.  No excuses, everyone had the same conditions.   Joe-JDC
« Reply #20 on: October 08, 2019, 02:09:38 PM »
You know what....you're completely right.
I still am not a fan of how their cell was designed however. I've got napkin sketches of how I want the dyno cell at my place to look like, it's got a filtered plenum box above the cell that would be ducted down to the carb. The barometric pressure reading and temp reading would come from inside that plenum box.
Superflow suggests 10 air exchanges per minute minimum inside the dyno cells, which as Joe described, creates a wind tunnel inside the room. I think the carb intake air needs to be separated from the room air to avoid situations such as that.
Royce
« Reply #21 on: October 09, 2019, 07:42:07 PM »
Back in the day...   Before wide band O2 sensors.... a bell with a turbine was fitted tightly over the carb intake.. On most dynos it pulled outside air so the engine would never get fed dyno room air... I think Jay still uses this setup.. Certainly not the JE dyno
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Katz427
« Reply #22 on: October 10, 2019, 09:02:02 AM »
In upstate New York, any opening on the roof that allows air or other products of the process to enter the atmosphere, we had to state to the DEC what the chemical composition of the air leaving was to our best estimate. I don't know about Ohio, but in NY it is a legal issue, air quality with oversight by the DEC. The owners of the building really frowned on putting any openings to the out doors except for the exhaust, which was necessary. We did have an A/C system with makeup air to keep temperatures inside the Dyno room reasonable.
57 lima bean
« Reply #23 on: October 25, 2019, 12:54:35 PM »
            An interesting video    .....   https://www.youtube.com/watch?v=XB_Q9qpvnL0
Royce
« Reply #24 on: October 25, 2019, 03:29:37 PM »
Geeze  I see a bunch of un-necessary stuff and then  missed opportunities to add another 30 or 40 horse without disturbing it's manners..  Steve dropped this here just to get a rise out of Joe and I...Mission accomplished !!   I ran a bone stock 58 292 2 bbl on the dyno and it made 215 horse.
1992 BMW V-12 5.0
« Reply #25 on: January 09, 2020, 11:04:42 PM »
I have finally gotten around to follow up on dyno testing of my EMC 303 Y Block, and found a couple of rookie mistakes that I don't understand, but it is what it is.  My timing when I took the engine off the dyno here in TX was best at 37* total, and produced the same numbers at 38*, so we decided to leave it alone and dial it back in Ohio if needed.  The horsepower was 453.7/390 tq and several pulls over 450 hp.  We were down 24/24 on our dyno pulls at EMC, and nothing we did seemed to affect it more than a few horsepower.  However, when I checked my timing here, it was set on 42*, and we never actually changed it during the dyno session (my mistake), or messed with it before starting the engine here this week.  That cost me about 12 of those 24 hp we lost, and we were starting to think maybe the dyno was a bit happy here, but it has not been in the past.  We bought two sections of 4" flexible exhaust tubing to add to my header extensions like they use at JE Pistons dyno cell, and lost another 10 hp, bringing the horsepower down to 430, which is what we made at EMC.  So, tuning for the small flexible exhaust tubing, and timing set way too high were responsible for the loss of the horsepower difference from TX to Ohio.  Took the exhaust tubing off, and set the timing correctly, checked valve lash, plugs, and made a couple of jet changes for the weather here, and we were back at 454 hp/389 tq.  Tried a new intake manifold, and hit 461.2 hp/399.7 tq with the same carburetor we used at EMC.  So the little Y now has 67 dyno pulls, makes over 461 hp, and nearly 400 tq.  Not too shabby for a 62 year old iron head Ford.  Joe-JDC
« Reply #26 on: January 10, 2020, 06:33:30 AM »
Good numbers for that old girl, and neat detective work.  It's amazing how little things make big differences.  Nice work
« Reply #27 on: January 10, 2020, 09:25:02 AM »
Amazing power from that 'ol Y Joe!  Could eat off of any part of it too. Do you plan to run this at some point in your '55 T-Bird?  ;D
Gregwill16
« Reply #28 on: January 10, 2020, 10:18:37 AM »
That would be alot of fun in little T-bird. Nice job!
« Reply #29 on: January 10, 2020, 01:08:33 PM »
It may find it's place in the '55 T-bird, but I have a 345 Y, and the 375 Y that I am working on, also.  The hp/tq cubic inch for an iron head and 10.4:1 compression is 1.522/1.319.  That is very efficient for what it started life as.  It actually will idle down to a decent 750 rpm, and sounds like no regular Y with the Mike Jones Racing camshaft.   I will be back on the dyno next week for another intake test, and a camshaft change to see if there is anything we left on the table with this build.  I ported that junky iron intake that I posted pictures of last year with all the rust pitting, and I ran it last after making the 461.2 hp, and the iron intake made 437 hp.  Not too bad for the old iron since it was only down 25 hp from the best aluminum intake available after porting.  I tried the new single plane Mummert intake that I ported, on this engine, and it is the one that made 461.2 hp. Joe-JDC
