Author Topic: Sparkplug gaps  (Read 3758 times)
preaction
Sparkplug gaps
« on: September 24, 2019, 01:21:07 PM »
While using an MSD box for ignition on a 10.5 comp fairly stout cam engine would .035 gap be a good starting point ?
cattleFEeder
Re: Sparkplug gaps
« Reply #1 on: September 24, 2019, 01:25:55 PM »
My .05 cents is .035 to .040 is a good place to be.
Remember, RPM is your friend
Re: Sparkplug gaps
« Reply #2 on: September 24, 2019, 01:45:20 PM »
I agree Im at 40 and its probably a tight 40.
Re: Sparkplug gaps
« Reply #3 on: September 24, 2019, 02:07:32 PM »
I like 0.035" even with a good MSD ignition.   I have a 10.5:1 engine and have tried wider gaps.  I never found any improvement.  I did think it missed in certain conditions with the wider gaps.  I think I went up to 0.040"-0.045".   I went back to 0.035" and have never had a problem since.
JMO,
paulie
GerryP
Re: Sparkplug gaps
« Reply #4 on: September 24, 2019, 03:19:12 PM »
JMO,
paulie
I had the same experience.  Using a Duraspark and MSD 6AL.  Engine started and ran reliably at .035.  I tried from .055 to .040 and it picked up misfire over .035.  My assumption was that modern inductive systems are running .060 gaps and seem to do fine.  Nope.
preaction
Re: Sparkplug gaps
« Reply #5 on: September 24, 2019, 09:59:08 PM »
Sounds good thanks for the replies. ;)
