Author Topic: Pipe Plugs into Aluminum Intake - Material ?  (Read 4648 times)
rockhouse66
« on: September 16, 2019, 05:16:10 PM »
I recall putting an aluminum fitting into an aluminum manifold and it seized up tight - like forever!  So, maybe I did something wrong or what is the best/better pipe plug material for aluminum intake manifolds?  I have brass and steel and am afraid of aluminum now.
I tried Google for this and - well - some say aluminum with anti-seize is fine and some say brass because it is close in galvanic properties.  Or stainless steel (harder to find).
Jim
kraut61
Re: Pipe Plugs into Aluminum Intake - Material ?
« Reply #1 on: September 16, 2019, 05:23:11 PM »
 Teflon tape...about three wraps. Be careful when tightening the fitting because the teflon is "slick" and the fitting can be over tightened very easily.
C6AE
« Reply #2 on: September 16, 2019, 10:28:17 PM »
Mcmaster Carr has hex socket pipe plugs in 316 SS
(not that expensive for a high quality part)
https://www.mcmaster.com/pipe-plugs
« Reply #3 on: September 17, 2019, 01:16:55 AM »
Stainless, and use an antiseize for aluminum.
Dissimilar metal issues on the boat all the time...
« Reply #4 on: September 17, 2019, 09:21:57 AM »
I use brass or aluminum - and always with anti-seize or teflon, PTFE paste, teflon tape.  Steel spark plug into aluminum heads - always anti-seize.
