Author Topic: Blue Thunder - HI Rise aluminum head torque specs  (Read 3416 times)
John67427
« on: September 07, 2019, 03:52:26 PM »
Would anyone have any info on torque specs? Blue Thunder aluminum Hi Rise heads on aluminum Shelby block. Going to have to do some maintenance and realize I have no info for torque specifications.
67428GT500
Re: Blue Thunder - HI Rise aluminum head torque specs
« Reply #1 on: September 08, 2019, 02:07:06 AM »
The listing is for ARP Studs. 95 FTLB in two increments with ARP lube.
CaptCobrajet
« Reply #2 on: September 08, 2019, 08:34:28 AM »
Be sure that you have anti seize on the studs in the block.  I torque the studs in the Shelby blocks to 15-20 to be sure the buttons are seated properly in the bottom.  With ARP lube on the washers and nuts, I would go "snug" in sequence, then 50 in sequence, 75 in sequence, and then 100 in sequence.
Blair Patrick
John67427
« Reply #3 on: September 09, 2019, 08:19:32 PM »
Thank you for the reply’s !!!
