Author Topic: Preferred Flat Tappet Lifter  (Read 12041 times)
66FAIRLANE
  • Andy
« on: September 02, 2019, 12:14:38 AM »
Is there a preferred brand of flat tappet solid lifter these days or any to avoid? ie. better metallurgy or foot radius etc that may help reduce failure.
Re: Preferred Flat Tappet Lifter
« Reply #1 on: September 02, 2019, 05:21:43 AM »
I use Crower or Trend EDM lifters when I do solid flat tappets.  They are SBF lifters so you have to use different length pushrods, but on a new build, you have to measure for new pushrods anyway.
I also order my cams with extra lobe taper.
CaptCobrajet
« Reply #2 on: September 02, 2019, 06:12:21 AM »
Depends on budget.  The best ones I get are tool steel shell lifters, but they are expensive, custom made stuff.  For budget minded situations, I use Crower with the Camsaver machining.  It is a small flat spot on the OD to oil the cam.  I do not use the EDM hole lifters.  That is a good place to dig a hole in my opinion.  A spinning hole in the center of a lifter running across the lobe is not the best option for me.  I like a smooth crown with the oil spinning in from that tiny flat right at the lifter bore.
Blair Patrick
66FAIRLANE
  • Andy
« Reply #3 on: September 02, 2019, 06:20:31 AM »
Thanks for the feedback guys. Since the Aussie dollar is at a 10 year low I am shelving my plans for a mild hydraulic roller & putting it back together with an old Crane Fireball 294 I used to run years ago. The lifters are long since departed so will do a break in procedure again with new lifters.
« Reply #4 on: September 02, 2019, 07:07:57 AM »
What about on a center oiler block?  Do the Camsaver lifters make any difference then?
thanks,
paulie
« Reply #5 on: September 02, 2019, 07:15:21 AM »
I really like the Camsavers on hydraulic cams.
As for the EDM hole lifters, I haven’t lost a cam yet to them, with up to 450 lbs open pressure.  Knock on wood............
To the OP, the Trends that I use are tool steel and are about 3 times the price of the Crower stuff, and the Crowers are about 50% higher than a traditional Comp/Crane dumb bell or shell lifter.  Much higher prices but IMO it’s worth it to keep a cam happy.
Paulie, the Camsaver and EDM lifters are designed to be used with pressurized oil.  Trend makes tool steel lifters without the EDM hole for such applications.  I’m doing a high riser build with a C/O block right now with that set up.
CaptCobrajet
« Reply #6 on: September 02, 2019, 07:28:33 AM »
Paul, I have Crower make shell lifters a few sets at a time with the Camsaver groove all the way to the top.  On pressure fed bores, the Camsaver groove only goes from the band to the bottom.  On solid lifter blocks with no oil, I thread the drain holes and put about a 1/2" pipe nipple in those holes.  It will flood flood the valley before it drains back.  Then, the full groove Camsaver will feed the lobes.  Just needs about one extra quart of oil for the pool that lives up top when the engine is running.  With warm oil, and the spinning lifter, it gives the lobes a supply of oil.
It is important to use open nipples if you do this.  Screwing a plug in those holes will inhibit crankcase venting.  Sometimes I get a block in here that someone has plugged.  This is not good, as it will create pressure in the crankcase.  If you use nipples, the oil will drain back to the timing cover, and go right back to the front sump.  On rear sump pans, I make provision to drain at the very back, but still maintain a pool for lifter oil.
« Last Edit: September 02, 2019, 07:46:05 AM by CaptCobrajet »
Blair Patrick
« Reply #7 on: September 02, 2019, 08:38:25 AM »
Although any bit of oil that dribbles around should be a little better, unless you are going radical, I just haven't seen flat tappet failures, solid or otherwise, after a good break in and good oil.  Admittedly, I run street lobes up to only about .600 lift, but I never think twice about them to tell you the truth
The absolute majority of the oil comes from the crank, so keeping idle on the higher side of what you like, running the right oil, correct spring pressure, and making sure the lifters are free to rotate and no binding in the valve train are the real must-dos.
As far as brands, I have a set of new Morels dumbells that are very pretty here, and likely leftover if you are in a bind.  However, I have bought bulk "Johnsons" off Ebay and they worked great on a 282S, who knows what they really were LOL  In the end, I think your oil and assembly will be the key factors
MeanGene
« Reply #8 on: September 02, 2019, 09:15:46 AM »
I have a set of Trend tool steel lifters, uncoated for cast cams, that have been on the shelf for a while. I did a lot of research at the time, but got sidelined with other stuff and haven't tried using them. I still haven't seen where folks have had problems or failures with them, seem like a great deal. I have seen it recommended to still follow a break-in procedure like a regular flat-tappet to allow the cam itself to get warm n fuzzy, is that what you gents do, and is it as easy as it seems? I have a .684 sft that would match up well with my 454, and not having to go roller would simplify things for now. Am I missing anything? For springs, would a lower-end roller spring work well? I have some Isky Tool Room springs that are not battleship spec, but reportedly good quality. What kind of pressures would be appropriate? Lower end is RPM-capable, Crower rods, light pistons and 3.98 stroked 391 steel crank. As always, I'm sure everyone is as thankful as I am when you guys share your knowledge and experience- Thanks!
« Reply #9 on: September 02, 2019, 09:23:25 AM »
I would use those and break in the cam like you would any other camshaft.
The spring pressures depend on the entire combination.  It's lobe shape and rpm dependent.   RPM of course depends on a ton of things, including how well the heads flow, the cam specs, etc.
FWIW, I've used nitrided cast cams and those Trend tool steel lifters with about 170 lbs seat and 450 lbs open on some 7000-7500 rpm applications.
MeanGene
« Reply #10 on: September 02, 2019, 11:34:42 AM »
Yep, that kinda where I was headed for pressures, thinking using the mild roller springs set up that way would have good life- I hear good things about the Tool Room springs
« Reply #11 on: September 02, 2019, 12:55:00 PM »
I am currently running about 150 lbs closed and 405 lbs open pressure.  It is a Compcams solid flat tappet that has been nitrided.  The lifters are standard Crower dumbells with an EDM hole.  They are not the SBF lifters,  they are FE dumbells.
It has worked okay for about 10 years, but maybe only 15,000 miles.  I am not not super confident about the combination because I set the valves a couple thousandths tighter every time I check the lash.
paulie
« Reply #12 on: September 02, 2019, 01:02:03 PM »
Thanks Brent and Blair.  I will be deciding what to do with my Center Oiler 427 pretty soon.  Tool steel or full-length Camsaver lifters sound better than drilling out the oil passage.
paulie
MeanGene
« Reply #13 on: September 02, 2019, 01:30:04 PM »
Any idea what it would cost to send one back in to be nitrided?
« Reply #14 on: September 02, 2019, 02:11:51 PM »
Paulie , your wear is more likely pushrod seats, cups and rockers due to the stout pressure.  If you were losing thousandths at the lobe, it would get ugly and especially not be uniform
