Author Topic: Edelbrock 60069 heads.  (Read 37780 times)
JimNolan
Re: Edelbrock 60069 heads.
« Reply #30 on: December 15, 2012, 10:06:42 PM »
427stang,
   Thanks, I'll leave them alone. Where they dump out into the engine they are wollowed out quite a bit. They're a lot bigger than the C1AE's. Jim
« Last Edit: December 18, 2012, 02:48:50 PM by JimNolan »
Qikbbstang
ARP FE Head Bolts absolutely SUCK!
« Reply #31 on: December 26, 2012, 12:11:50 AM »
 I disassembled and assembled an Edelbrock headed 390 that had ARP head bolts. The nightmare was ARP used a reduced socket size then factory Ford. The problem was they did that with a 6-point head not a 12-point as is the custom when dealing with higher torque on a smaller bolt head. Man getting a weenie 6-point broken loose and later torqued up was scarry for it wanted to slip off and you could tell it did not like seeing that much force.
JimNolan
« Reply #32 on: December 26, 2012, 08:39:04 AM »
Qikbbstang,
     As I was pulling up the last head bolt on the 1st Edelbrock head that required 110 lbs torque. The torque wrench broke loose and I instantly thought I'd broke the ARP bolt or the threads came out of the head. I felt like throwing the torque wrench across the room or at least cussing out some idiot that thought 110 lbs was needed to torque down a head.  I put the torque wrench back on it and started pulling to see if the threads were gone. I estimate at about 80 lbs the torque wrench broke loose again. The socket had rounded off inside thank God. I torqued the other head to 100 lbs with a new socket and left them there. After I get about 30 minutes run time on the stand I'll retorque to 100 lbs. I don't want to go to 110 again. 100 lbs should torque a head down. Wouldn't ya think?
afret
« Reply #33 on: December 26, 2012, 11:21:33 AM »
I've read that ARP recommends 75 ft-lbs or so with ARP lube which is different from Edelbrock.  I've been taking the head bolts to 85-90 ft-lbs with ARP lube.  Others have used the Edelbrock numbers with no problems.  If your block has been torque plate honed, I would use the torque that was used with the torque plates.
ARP seems to have come out with a new lube so I don't know what that does to the numbers.  LOL
I think you will be fine.
« Reply #34 on: December 26, 2012, 02:42:50 PM »
ARP's new lube is not as slippery as the old stuff, so the torque numbers with the new lube will be lower than they were with the old lube.
jmlay
« Reply #35 on: December 26, 2012, 05:08:25 PM »
If not as slippery the tq would go up, more effort for the same clamping force.
Mike
Mike
JimNolan
« Reply #36 on: December 26, 2012, 05:18:44 PM »
I decided to retorque the top row of the 1st head to 100. That way they'll all be the same like the last one I put on. Shouldn't hurt anything. I hope.
« Reply #37 on: December 26, 2012, 06:10:35 PM »
You'll be fine
Get the old girl running already :)
(Who am I to talk, I did initial break in for the 445, but still no fenders or doors on the truck LOL)
« Reply #38 on: December 26, 2012, 09:04:33 PM »
Mike
Yep,  I think I had it backwards.  The new lube is more viscous than the old ARP lube, but maybe it is actually more slippery.  To get .006" stretch on a Crower rod bolt I needed 82 ft-lbs with the old lube, but only 75 with the new stuff.
390 Cougar Conv
« Reply #39 on: January 16, 2013, 01:27:52 AM »
Where can one get a burette for CCing???  Clifford
1969 Cougar XR7 GT 390 S Code C-6 Convertable
1965 Comet Caliente 302 C-4 Convertable
« Reply #40 on: January 16, 2013, 08:56:04 AM »
Summit Racing sells them, just do a search on "burette".
390 Cougar Conv
« Reply #41 on: January 16, 2013, 09:02:51 AM »
Thanks Jay.  Clifford
fe66comet
« Reply #42 on: January 16, 2013, 10:16:14 AM »
I just use a veterinarians syringe they come in huge sizes then there is little math involved.
390 Cougar Conv
« Reply #43 on: January 16, 2013, 02:12:27 PM »
Thats a good idea, never thought of that. Thanks Clifford
