Author Topic: Wilwood master cylinder with pentroofs, fitment in 67 Fairlane?  (Read 2985 times)
6667fan
  • Every Second Counts
I searched threads here for Wilwood masters and did not see what I need to know. How does their master cylinder fit in a 67 with pentroofs? Car has a 15/16” bore Ranger m/c currently and stops for sh#t. Might try 7/8”. Factory disc set-up with 2.5” drums out back. No booster.
Speaking with Wilwood tech they suggested 7/8” might be the way for me to go. I will confirm my pedal ratio of course but the last time I measured it I thought it was reasonable.
Thanks,
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
cattleFEeder
Re: Wilwood master cylinder with pentroofs, fitment in 67 Fairlane?
« Reply #1 on: August 18, 2019, 01:33:37 PM »
It fits but its close, luckily the wilwood arm is ball that pivot's so I have a spacer to push it to the side. Stops fine, I do not notice it at all when braking.
« Last Edit: August 18, 2019, 02:22:12 PM by cattleFEeder »
Remember, RPM is your friend
6667fan
« Reply #2 on: August 18, 2019, 04:12:30 PM »
Thanks for responding plus bonus pic. Are you saying the arm that attaches to the brake pedal has a heim joint which allows for some flexibility when the master is cocked? I have the Ranger one shimmed currently.
JB
JB
67 Fairlane 500
482 cid 700/617
cattleFEeder
« Reply #3 on: August 18, 2019, 04:47:54 PM »
Yes sir you are correct on the arm. Here is the 1 I am using. Now it has the correct link
https://www.summitracing.com/parts/wil-260-12900-bk/overview/year/1969/make/ford/model/mustang
« Last Edit: August 19, 2019, 05:39:08 PM by cattleFEeder »
