Author Topic: 4.375 Cranks, are they gone?  (Read 13067 times)
Re: 4.375 Cranks, are they gone?
« Reply #15 on: August 19, 2019, 09:00:02 AM »
Blair sent this over to see if I could figure how to load it up on here. The only way I could get it done is to load it up on my youtube. Video is blurry, but the sound is nice!
Not my engine by the way
https://youtu.be/HpOKIP6aa50
« Reply #16 on: August 19, 2019, 10:12:49 AM »
We did a 4.750 SOHC crank a couple years ago.  I recall it taking nearly a dozen slugs
« Reply #17 on: August 19, 2019, 11:40:59 AM »
That was Andy's crank, I figured if he could do, so could I  ;D  Barry, do you remember what brand that crank was?  Scat maybe?
« Reply #18 on: August 19, 2019, 04:54:58 PM »
It was/is indeed.  A Scat billet and custom steel rods from R&R (no longer doing those from what I hear).
We had the clearance the entire innards of that Pond block.
I thought I was the first to go that big on an FE, but the guys at Scat said they had one in their records from "once upon a time"...
KMcCullah
« Reply #19 on: August 19, 2019, 10:36:10 PM »
Wow! Now that is some FE thunder. Nice work, Blair! Thanks for putting the video up, Mike. Waaay sexy looking header too. I hope the proud owner of that engine comes on and tells us about it.
I've been thinking about offset grinding my 4.375 crank for a while. Anybody tried that yet?
Kevin McCullah
CaptCobrajet
« Reply #20 on: August 19, 2019, 10:47:55 PM »
Might be a little scary Kevin !  You would need to go to 2" crankpin, which means re-heat treat.  The overlap would be reduced......not sure the RPM crank can stand it.  Might be better to do a custom forged Scat, and then sell what you take out.....
Blair Patrick
427HISS
« Reply #21 on: September 05, 2019, 02:12:11 PM »
Man, what was the screaming RPM ?  Wow !
« Reply #22 on: September 05, 2019, 03:24:56 PM »
X2 on the wow
