Author Topic: Rear main seal material  (Read 4072 times)
TJ
« on: August 08, 2019, 08:57:50 AM »
Replacing the rear main seal in my 3.8L mustang.  I have a choice of rubber, viton, or teflon.  Anyone prefer one of these over the other?  Is the preference for ease of install, longevity, etc?  Thanks
BTW, it's a once piece seal that rides the crank flange.
Re: Rear main seal material
« Reply #1 on: August 08, 2019, 09:13:06 AM »
Any will work.
Viton seals are nice.
Teflon seals go on dry.  They burnish themselves into the crankshaft to seal.
Bolted to Floor
« Reply #2 on: August 08, 2019, 12:38:47 PM »
From dealing in the oil and gas industry, the Viton should hold up better to the oil.
RustyCrankshaft
« Reply #3 on: August 08, 2019, 05:57:00 PM »
Viton. Lasts longer than rubber, more durable than teflon in a lip seal configuration.
TJ
« Reply #4 on: August 09, 2019, 08:10:06 AM »
Thanks to all for the info.  I'll try a viton.
I read somewhere about Teflon needing to be installed dry on a dry shaft.  I might try that someday on a seal that doesn't take so much effort to inspect.
