Author Topic: Driveline vibration  (Read 21206 times)
Royce
Driveline vibration
« on: August 07, 2019, 03:31:09 PM »
My 61 Starliner has a resonating drive line vibration . The frequency leads me to the drive train... So far I have replace U joints,balanced the drive shaft,  inspected the axle bearings, and even changed out the gears.. No change... The vibration is rpm related and is worse under power and less if you let off the gas..I am 95% sure it is not coming from the engine compartment..  I would have put my money on the drive shaft but the shop said it was perfect.
Any ideas
RB
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
shady
Re: Driveline vibration
« Reply #1 on: August 07, 2019, 03:37:37 PM »
Tranny output shaft bushing or bearing? Torque converter?
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #2 on: August 07, 2019, 03:38:16 PM »
Which engine and trans?
« Reply #3 on: August 07, 2019, 03:40:00 PM »
Has a clutch fan gone south?
Have you considered running the engine and drivetrain on a very well blocked up car?
C6AE
« Reply #4 on: August 07, 2019, 03:41:30 PM »
"Hunting" gear set in the differential?
gt350hr
« Reply #5 on: August 07, 2019, 03:43:09 PM »
   Royce ,
      Look at your pinion angle. It could be pointing up too much and under power it rises even more creating a vibration. You may have already done that . It happened to me is why I relate it. Same MO , balanced , checked for straightness , new U joints etc. Bad angle.
    Randy
chilly460
« Reply #6 on: August 07, 2019, 04:54:15 PM »
Following as I have same issue, not terrible but I’ve fixed all the other nagging items so will look into this over the winter.  Mine has a specific speed it occurs and it rolls in/out
Royce
« Reply #7 on: August 07, 2019, 04:59:40 PM »
Randy  Pinion angle passes the eyeball test but I will put a angle finder on it..
 Jay, I so want to say a 292 and a 3 speed... But it is a 390 and a C6  Trans output bushing is tight.. Pray it is not the torque converter.. It was replaced about 1000 miles ago with a higher stall unit.. Does not have a clutch fan.. Getting a the vibration to come and go by getting on and off the gas keeps me thinking somewhere between output on trans and rear gears
1992 BMW V-12 5.0
« Reply #8 on: August 07, 2019, 05:08:30 PM »
Royce, is this a new development or has the car always had this since you've owned it?  If its new, what changed around the time that it started vibrating?  I think it would be worth looking at the torque converter and flywheel.  Maybe somebody stuck a 428 flywheel on the 390, or a balance weight fell off the converter, loose converter bolts, loose flywheel bolts, or something in that area...
Royce
« Reply #9 on: August 07, 2019, 05:21:07 PM »
I barely drove the car when I bought it before pulling the motor for a detail job and a makeover to 390 375 horse dress.. I don't recall if vibration was present.. Since then it has a new converter but original flex plate. I put it all back together. (Definitely a possible source of error)  I'll check the converter bolts and see if I can see anything on the flex plate or converter..
Maybe Brad Ford  knows of some gizmo that can isolate sources of vibration
1992 BMW V-12 5.0
« Reply #10 on: August 07, 2019, 06:06:48 PM »
...Maybe Brad Ford  knows of some gizmo that can isolate sources of vibration
BradFord is actually very good at diagnosing driveline vibrations, he’s helped me a couple times. Sadly no gizmo involved, you need the actual BradFord. A phone call to him might get some suggestions though. I haven’t been able to get him to check the forum on a daily basis yet.
badcatt
« Reply #11 on: August 07, 2019, 06:36:18 PM »
Does it do it in Neutral or Park? I'm chasing a vibration in a fresh 351C. I too thought it was drive line. But after R&Ring U-joints it still did it. I then checked in Park and it was there. Currently I do not have a diagnoses.
66FAIRLANE
  • Andy
« Reply #12 on: August 07, 2019, 07:26:33 PM »
Had a vibe many years ago I couldn't find. Very subtle & only at higher speeds. One day a mate was driving behind me and when we stopped he said "I think your left axle is bent". I put a clock on the wheel rim & sure enough there was wobble, wasn't much, but was enough. Changed the axle, vibration gone. Just something else to check if its only there on road.
cattleFEeder
« Reply #13 on: August 08, 2019, 07:17:25 AM »
Just had the same problem on my 63.5 galaxie ended up being a wobble from an aftermarket rim that wasn't welded strait at the factory.
Remember, RPM is your friend
« Reply #14 on: August 08, 2019, 07:55:36 AM »
Sounds like pinion angle to me too
