Author Topic: Timing 1967 Shelby 428. Anyone have the spec?  (Read 3415 times)
67428GT500
« on: August 05, 2019, 08:45:29 PM »
I can't locate my performance manual and I am setting the distributor in. To my recollection is was about 6 degree BTC.  Can anyone this?
        -Keith
machyoung
Re: Timing 1967 Shelby 428. Anyone have the spec?
« Reply #1 on: August 05, 2019, 08:53:16 PM »
The book may say 6 (or even 8), however your engine and therefore you will be a lot happier with 14-16. Just my 2 cents!
67428GT500
« Reply #2 on: August 05, 2019, 08:55:31 PM »
I thought it was originally set at 16 or 18 and 38 degrees to total at 2700 rpm. Been a while.
        -Keith
67428GT500
« Reply #3 on: August 06, 2019, 09:54:28 PM »
Factory settings are 6 degrees BTC.   For others than may need help.  I set it at 10 degrees.
        -Keith
Ranch
« Reply #4 on: August 07, 2019, 05:38:59 AM »
If you are happy with the curve in your distributor then just put a 38* mark on your balancer.  Then with your timing light hooked up bring your RPM's up to 3K and make a any adjustments....JMO
      Bill
67428GT500
« Reply #5 on: August 07, 2019, 07:30:58 AM »
Hi Bill:
I posted a request for factory initial timing according to Shelby spec. I remembered the factory decal was still on the head and used it for reference. The original decal on the head is showing 6 degrees BTC. However, to drop the distributor for initial start up timing I used the CJ spec and turned the damper to 10 degrees BTC and dropped the distributor in on number one.
        -Keith
