Author Topic: ARP Rocker Shaft Stud Length with Edelbrock heads.  (Read 2956 times)
67428GT500
« on: August 03, 2019, 07:59:34 AM »
I installed the ARP rocker studs that I was running with my iron heads. The tapered stud that is specific to the oiling that has a flange stop above the threads seats before the flange seats against the head.
Is this a concern, or run it as is? It seems to be about .250 taller than the other studs.
        -Keith
Re: ARP Rocker Shaft Stud Length with Edelbrock heads.
« Reply #1 on: August 03, 2019, 11:11:06 AM »
That stud is shorter for aluminum heads, if you have enough threads it should be fine but typically you match the studs to the type of head
