Author Topic: Is a 3.375 too big of a bore for 428's ?  (Read 14672 times)
427HISS
« on: July 06, 2019, 12:55:53 PM »
I have a set of MAHLE slugs, is a 3.375 too big of a bore for 428's ?
I see them listed from 3.125, 3.250 and 3.375 for an FE.
Re: Is a 3.375 too big of a bore for 428's ?
« Reply #1 on: July 06, 2019, 12:59:12 PM »
Maybe you meant....I have a set of MAHLE slugs, is a 4.375 too big of a bore for 428's ?
I see them listed from 4.125, 4.250 and 4.375 for an FE. ;)
BH107
« Reply #2 on: July 06, 2019, 03:23:52 PM »
And I’m sure you are referring to the stroke, not the bore.
« Reply #3 on: July 06, 2019, 04:21:25 PM »
If you meant 4.375 bore  it is to big for a 428
« Reply #4 on: July 06, 2019, 08:58:25 PM »
42 bottles of Beer on the wall 42 bottles of beer, take one down and .... lol
427HISS
« Reply #5 on: July 07, 2019, 01:27:55 PM »
Yes, bore. Anyone want to trade for a 4.125 or 4.250 ?
From what I see, that size is for like 500c.i
« Last Edit: July 07, 2019, 04:14:39 PM by 427HISS »
fe-starliner
« Reply #6 on: July 07, 2019, 04:54:45 PM »
427hss....what FE block has a 3.125 bore?  I'm confused.
1960 Starliner, 406-6V, TKO-600, 4.11 9"
1961 Starliner, 427 4V, SS700 5 speed, 4.56 9"
1968 F-100 SWB, 352 4V, C6, 3.25 9"
2012 Mustang, 226" V6, 6 speed auto, 3.31 8.8"
427HISS
« Reply #7 on: July 07, 2019, 06:17:42 PM »
The piston box reads
4.375. + .005 1.5 3.0MM FILE FIT
FFE267375120
PR# 99-9021
Ford FE 20cc DISH
Bunch of other numbers and abbreviations as well.
So what size bores would these pistons be for ? I'm confused too.
« Reply #8 on: July 07, 2019, 06:32:08 PM »
Some aftermarket FE blocks can take a 4.375" bore.
427HISS
« Reply #9 on: July 07, 2019, 06:59:51 PM »
Wish I could afford a BBM, Side Oiler Garage, Genesis, Pond or Shelby FE block.
I have the pistons, rods, Dove complete heads, EFI intake system, MSD etc. Almost everything but the block and frank.
The popular 482 cu. would be very close to my dream engine.
« Last Edit: July 07, 2019, 07:03:55 PM by 427HISS »
« Reply #10 on: July 08, 2019, 06:05:30 AM »
FFE267375120
PR# 99-9021
Ford FE 20cc DISH
https://www.cnc-motorsports.com/mahle-pistons-ffe267375i20-forged-inverted-dome-4375-bore.html
Those pistons are designed to work with a hard to find 4.375 stroker crank, 6.70 BBC rods and only an aftermarket block at 4.375 bore.  (No Ford block, not even a 427, can be bored to use those pistons)
You may be able to use those with an aftermarket block, a 4.125 crank, and a 6.8o BBC rod, but they will be approx .025 in the hole and require a thin head gasket, and you wouldn't be saving much money and giving up displacement and potentially quench
That is a very unique set of pistons to end up with, unusable for 90% of the people on this forum, and only then by spending quite a bit of money
427HISS
« Reply #11 on: July 08, 2019, 10:30:44 PM »
I believe my engine builder ordered these because at the time, we bought a Genesis block. Would their block handle that large bore ?
« Last Edit: July 08, 2019, 10:42:23 PM by 427HISS »
ntheogen
« Reply #12 on: July 09, 2019, 11:14:03 PM »
Yes it would but no stock block would go that large.
« Reply #13 on: July 10, 2019, 02:18:06 AM »
Hey that is what I want to build but I was going to use a flattop. What compression ratio as those with a 72cc chamber?
« Reply #14 on: July 10, 2019, 06:35:04 AM »
11.41:1 at .005 below deck and a 1020 gasket with a 4.375 stroke crank, under 11:1 if you went short stroke and a 6.80 rod.
