Author Topic: Anyone recognize these valve springs ?  (Read 2932 times)
BigBlueOvalFan
« on: July 01, 2019, 08:25:25 PM »
I'm trying to give a full accounting of the engine components for this build and I have little to no info.  These are double valve springs w/o damper and have a dark greyish/goldish hue.  They measure 2.334" total uninstalled height, Coil Bind at .973, O.D. is 1.537", 2nd O.D. is 1.118" and I.D. is .816".  They have a seat pressure of 200lb with installed height of 1.879", Open Pressure is 500lb at 1.319" (Measured for .645" valve lift for solid roller cam).
Anyone have a clue as to who made these ?  I've searched, Crane, Comp, Lunati and tried to match it up to something they sell but no luck.  Any additional info needed or if I've missed something, just let me know.
Thanks, Jim
gt350hr
Re: Anyone recognize these valve springs ?
« Reply #1 on: July 02, 2019, 10:16:31 AM »
   Jim ,
    Most likely the spring was "made" by Associated - Raymond Spring Division and sold by any vendor that bought them. I know Sig Erson used a spring like that and so did Norris and Racer Brown. It is a high quality chrome- silicon , shot peened spring  that "in the day" was used for moderate roller cams. It had good life if held to 7,000 rpm.
    Randy
BigBlueOvalFan
« Reply #2 on: July 02, 2019, 03:55:08 PM »
Thanks Randy, any and all info helps.
