Author Topic: Tube headers for 63-64 Galaxie?  (Read 6909 times)
GJCAT427
« on: June 25, 2019, 05:13:07 AM »
A while back some one posted a picture of a tube header next to a stock long cast header. They looked alike. Can some one repost that picture and who made(makes) them?
Re: Tube headers for 63-64 Galaxie?
« Reply #1 on: June 25, 2019, 08:58:35 AM »
I don't have a pic of them next to each other, but I think the FPA headers are pretty close:
IMG_1492 by Drew Pojedinec, on Flickr
IMG_1493 by Drew Pojedinec, on Flickr
Required a little grinding on the passenger side upper A-arm, and some other minor fitment stuff, but otherwise they've been great.
« Reply #2 on: June 25, 2019, 01:05:52 PM »
Ya, I'd say those Tri Y design duplicates the cast iron factory versions.  It's only missing like 50# of cast iron LOL!!
« Reply #3 on: June 25, 2019, 01:46:20 PM »
Those look good, looks like 2" primary tubes.
GJCAT427
« Reply #4 on: June 25, 2019, 03:26:20 PM »
Drew, those look like the ones I`m remembering. That sure would save some weight on the front.
GJCAT427
« Reply #5 on: June 25, 2019, 06:21:07 PM »
Went to FPA website but couldn`t find any pricing. Drew what did yours run if I may ask? And did the clutch linkage need modifying?
« Reply #6 on: June 25, 2019, 06:52:25 PM »
My FPAs knocked the heck out of $1000. delivered to my door in SE Tx.
« Reply #7 on: June 25, 2019, 07:15:20 PM »
Yeah, they retail for $1000.
I got stupendously lucky, just when I got to the place in my build where I needed headers, I looked on ebay and a fella had a set for sale.  He had test fit them but had rack and pinion steering and they wouldn't work.  I bought them $500 shipped with a few scratches.
They have held up very well, I didn't have a break in stand or anything, so I dulled the ceramic coating pretty badly while breaking the cam in (I knew I would), but otherwise they work great.  As stated, a lil trim on the upper a-arm, and that is about all I needed to do to get them to work for me.  I'd buy them again if I needed to.
I do not have a clutch linkage, as I run a c6, and have a cable driven shifter, so I cannot comment on that.
My whole engine build was pretty lucky like that... every time I needed something, one popped up for a reasonable price just when I needed it and I happened to have the money.
Guess that is why I was smiling (probably as close as it gets to a smile anyway)
BT intake by Drew Pojedinec, on Flickr
« Reply #8 on: June 25, 2019, 07:24:47 PM »
If you need any pictures of them installed, let me know tonight or tomorrow as I ship out Thursday 0200.  I know I don't have a clutch or the linkage, but maybe it'll help anyway.
GJCAT427
« Reply #9 on: June 26, 2019, 04:45:13 AM »
Drew, some installed pictures would be nice. Right now my 63 has the cast long tubes in there and I had a little trouble with the clutch linkage, but I got it to work. The new motor is a tunnel port with one of Jays adapters and a aluminum sheet metal top I built. Going to put a Lakewood bell in.  Thanks Garry
chilly460
« Reply #10 on: June 26, 2019, 06:30:10 AM »
I have FPAs in a ‘63 Merc, no issues with stock clutch linkage
« Reply #11 on: June 26, 2019, 04:19:01 PM »
I'm sure Chilly's input is all you needed, but I took some pics anyway.
IMG_1738 by Drew Pojedinec, on Flickr
IMG_1739 by Drew Pojedinec, on Flickr
IMG_1740 by Drew Pojedinec, on Flickr
IMG_1741 by Drew Pojedinec, on Flickr
IMG_1742 by Drew Pojedinec, on Flickr
IMG_1743 by Drew Pojedinec, on Flickr
I remember now, it was where the A-arm stud went on the passenger side that I needed to trim.
I also zip tied these headers in place when I installed the engine, so I can't comment on how hard it would be to remove or install with the engine in place.
GJCAT427
« Reply #12 on: June 26, 2019, 06:57:12 PM »
Thanks Drew. After looking at your pictures I seem to remember some grinding on the upper Arms on mine. The cast headers fit very close and I have in all the years I`ve owned it, never got the front aligned!  I did put a tie bar in to keep it from wallowing in the corners. This stiffened the front up a lot. I`ll study your pictures and figure if I want to go to headers. Thanks again Garry
« Reply #13 on: June 26, 2019, 08:18:11 PM »
Seems like with these cars ya just get the best you can.  Mine drives fine despite the alignment guy having a fit over the thunderbird spindles throwing stuff off.
*shrugs*
Works well enough, but I drive an 76F100 as a daily, so I'm used to a slightly more vague steering.
« Reply #14 on: June 27, 2019, 07:36:00 AM »
Drew, do you have '77 Tbird brakes on it?  My wagon goes dead straight at 120 mph without issue and NEVER been aligned and still all original front end parts.
I just put all that Tbird stuff on the black car, though it has all new parts and been aligned a few times previously.   Though I'm not real happy with the job done in the past I'm not taking it anywhere.  I'll use a string and some 2x4" on the ground to check the alignment.
« Last Edit: June 27, 2019, 01:17:17 PM by BattlestarGalactic »
