Author Topic: I'm sure some of you guys have seen this  (Read 5961 times)
GJCAT427
Re: I'm sure some of you guys have seen this
« Reply #1 on: June 23, 2019, 04:39:53 AM »
Looks like a second stress crack just below the first one 90*. I wonder what caused it to crack in the first place? Could be Tig welded and re drilled.
wowens
« Reply #2 on: June 23, 2019, 06:28:26 AM »
This may be why no BBM aluminum blocks on the market. Appears to be cast exactly as the iron block.
Woody
GJCAT427
« Reply #3 on: June 23, 2019, 07:31:16 AM »
Could be casting flash In that #3 main area. Hard to tell without a closer picture.
« Reply #4 on: June 23, 2019, 09:32:07 AM »
Repairable.  Not sure how you do that in the first place.  Dropped it with studs on?  Hydraulic locked bolt?
« Reply #5 on: June 23, 2019, 09:33:26 AM »
Odd, very odd it cracked after it was run-in and not at initial torquing. Can be fixed but......
« Reply #6 on: June 23, 2019, 10:02:12 AM »
It seem to have a sturdy main Saddle bulkhead based on the pictures compared to Ponds aluminum block . Sure is a weird place for a crack
C8OZ
« Reply #7 on: June 23, 2019, 10:12:57 AM »
I wonder if a front motor plate changes the loads in that area at all.
« Reply #8 on: June 23, 2019, 12:34:46 PM »
I bet you are right.  Had a Honda SCCA racer guy come to me for a build, (yuk, but might do it for something different LOL) broke a block because he oiled the studs "real good" and then tightened them by double nutting them.......    :o
« Reply #9 on: June 25, 2019, 12:44:12 PM »
Talked to a friend about this....he's confident it could be repaired, but would need to dig away that whole corner and build it all back up.
So if anyone is wondering, it is repairable, but needs to be done by someone pretty dang good.
CDXXVII
« Reply #10 on: July 02, 2019, 11:49:19 AM »
Somebody got the whole pack for less than $3000?
