Author Topic: 526 SOHC rotating assembly  (Read 8099 times)
338Raptor
« on: June 10, 2019, 10:51:32 AM »
Based on input from FE Power members I have fine tuned my specs for the SOHC I will soon begin to build for my ‘67 fastback.  The specs for the chassis are listed below in my Signature.  My next step is to determine which crank/rods/pistons will best suit my needs.  Before I get to the questions I’ll list the specific details of the engine.
Shelby large bore aluminum FE block (4.375 bore)
4.375” (526 cid) or 4.5” (541 cid) 4340 forged crankshaft
Pond SOHC heads
Jay Brown SOHC rocker arms
11:1 static compression ratio
93 octane pump gas
Hilborn EFI
Holly HP EFI system
Custom 2” headers
Cam specs are still undecided but they will need to be big
Car use: 90% street, 5% drag, 5% autocross
Curb weight is unknown but I would estimate it to be a couple hundred pounds less than stock.
Target horsepower and torque:  800 hp @ 7000 rpm and 700 Torque @ ???.
I want to focus on utilizing relatively light weight internals without compromising too much in strength. I’m running an aluminum flywheel and drive shaft. I figure with such large hemi pistons and a heavy crankshaft my internals are going to be heavy relative to most other builds.  I just want to minimize how heavy. That leads me to my questions:
1. Am I wrong to focus on internal weight?  Are the small weight savings of these parts just not noticeable in a 500+ cid engine?
2.  Trying to minimize weight, would I be sacrificing too much strength by utilizing K1 or Molnar connecting rods.  Respectively 781 & 797 grams vs. 860 grams for Crower sportsman’s. Is this enough weight savings to be able to “feel”?  Or should I look at another rod option?
3.   Is the RPM forged 4.375” crankshaft strong enough for my build?  And if so, is it worth the effort to lighten it or should I look at a custom light weight crankshaft?  Which crankshaft do you guys recommend?
4.   Which 4.375” piston (11:1 compression) would you recommend?  Does anyone have weights for different SOHC pistons?
Thanks in advance for sharing your knowledge and experience.
1969 Shelby GT350, 4 speed.
1964 Galaxie 500XL, 35 spline 3.70 Strange S-Trac, 6R80, (Coming soon: Pond Aluminum 525 SOHC, 800hp)
Re: 526 SOHC rotating assembly
« Reply #1 on: June 10, 2019, 11:06:46 AM »
I would think the parts you have chosen will be fine on a 800 HP build including the Molnar rods
« Reply #2 on: June 10, 2019, 11:10:57 AM »
No RPM cranks available at this time.  I would do a custom Scat.
You will not feel any differences in weight that you have outlined but a lighter rod and piston would make balancing a shelf crank easier.
Almost any piston manufacturer could make that piston for you.  Diamond, Racetec, CP, you name it.
« Last Edit: June 10, 2019, 11:14:28 AM by blykins »
338Raptor
« Reply #3 on: June 12, 2019, 08:30:21 AM »
Has anyone heard of strength issues with the K1 H-beam Rods?  They only weigh 781 grams.
I e-mailed them my specs and asked them the horsepower capacity at 7500 rpm with a heavy Hemi piston and they replied 1600 hp.  That seems a little exaggerated.
« Reply #4 on: June 12, 2019, 08:57:12 AM »
K1 and Molnar are essentially one in the same.  Tom Molnar used to work for K1.
I've never used K1 rods but with these situations, I would be reaching for a Crower/Oliver/Carrillo.
Dumpling
« Reply #5 on: June 12, 2019, 09:15:22 AM »
JMO, but 11:1 on 93 octane is optimistic/hopeful/unrealistic...again, JMO.
« Reply #6 on: June 12, 2019, 09:30:22 AM »
The right combo will run on 93 octane, but the overall package has to work together.
« Reply #7 on: June 12, 2019, 11:21:38 AM »
Is a 2" primary tube big enough for a 500+ CID SOHC?
Maybe Werby can run his magical program.
Dumpling
« Reply #8 on: June 12, 2019, 11:44:06 AM »
Thinking about it, the Hilborn is IR;. its runners may not be big enough to supply a 500+ cubic inch engine.  I think Hilborn offers (offered?) a larger runner version (58mm?) once upon a time.
338Raptor
« Reply #9 on: June 12, 2019, 12:28:51 PM »
Hilborn quoted me 2-7/16” butterflies and 65# injectors based on my combo.  It’s my understanding 2” primaries can support 850hp. Does anyone have a different opinion?
Dumpling
« Reply #10 on: June 12, 2019, 12:36:03 PM »
So, 64.5 mm...
Way beyond "normal"
338Raptor
« Reply #11 on: June 12, 2019, 12:51:28 PM »
Keep in mind it’s a SOHC manifold not a standard FE manifold.
hwoods
« Reply #12 on: June 12, 2019, 06:42:22 PM »
Crower custom billet crank only $4K now
Ford 352-427-428 Custom Billet Crankshaft
Part Number: 95191C
Be the first to review this product
Ford 352-427-428 Custom 4340 Billet Crankshaft
$3,977.89
you could be the first to review this product
338Raptor
« Reply #13 on: June 12, 2019, 09:56:31 PM »
I understand $4000 for a crankshaft in a high horsepower race engine is justified. But it seems a little excessive for a 800 hp engine.  I want good reliable parts but I would think there has to be a crank that would handle 800 hp at 7500 rpm for less than $2k.
wcbrowning
« Reply #14 on: June 13, 2019, 12:22:19 AM »
The problem is the long stroke you want.  As far as I know, the only way to get anything more than 4.375" is to go billet.  I don't think there are any forged units available with a longer stroke than that.
