Author Topic: Edelbrock Heads Factory Valve Springs With Cam Profile.  (Read 4109 times)
67428GT500
« on: June 07, 2019, 07:30:23 PM »
The Edelbrock heads I bought have a spring spec of 130 on the seat and 335 @ .600.
I put my cam card up to see what the peanut gallery says about use of the single spring with my cam.
GerryP
Re: Edelbrock Heads Factory Valve Springs With Cam Profile.
« Reply #1 on: June 07, 2019, 08:16:33 PM »
The springs are up to the task for that cam.
« Reply #2 on: June 07, 2019, 09:32:52 PM »
What valve stem diameter, head size, and retainer used?  Stock Edelbrock stuff?  When I checked the last couple of sets of Edelbrock Performer RPM heads, the springs had 140-145# seat pressure which was needed.  I don't think 130# is enough for a 3/8" stemmed valve and .560" lift.  JMO, Joe-JDC
67428GT500
« Reply #3 on: June 07, 2019, 11:04:41 PM »
They are .380 stem. I am changing the 2.09/1.65 valves with 2.19 INT 1.75 Exh.  The specs are for the Edelbrock springs for non-roller cam applications. The specifications you provided DD is for the roller cam ready heads.  I am hoping they don't really need to be changed. The springs on the C6AE-R I have now are about 140 on the seat and 365 @.0600. I have sold the C6AE-R heads to a forum member so I will have to pull these if they aren't enough for the cam to be safe to at least 6K
« Reply #4 on: June 08, 2019, 05:41:33 AM »
Pretty lazy hydraulic flat tappet.  It will be fine, but if it's a new cam that hasn't been broken in, I would use another spring.
67428GT500
« Reply #5 on: June 08, 2019, 06:38:44 AM »
It was ran in on a heavier double spring.  I was debating if the springs are weak. So what is a matter with the profile?
« Reply #6 on: June 08, 2019, 07:01:50 AM »
Nothing wrong with it, it's just a lazier lobe, so it doesn't need a lot of spring pressure.
« Reply #7 on: June 08, 2019, 07:12:46 AM »
Plenty of spring
