Author Topic: 64 Galaxie 390 into 66 Comet  (Read 5087 times)
Ctcobra
« on: June 04, 2019, 01:13:02 PM »
I am planning on installing a 390 from a 64 Galaxie into a 66 Comet. Will the Galaxie oil pan work or do I need a Fairlane/comet pan?
Thanks!
Steve D
Re: 64 Galaxie 390 into 66 Comet
« Reply #1 on: June 04, 2019, 04:37:09 PM »
The 64 Galaxie oil pan will not have the shallow rear section, with the indents for inner tie rod clearance, can`t say for sure it the tie rods will hit for certain on hard turns, but I would guess it could be a problem. A bigger problem will be how you resolve the motor mount problem. A 64 block will only have the narrow 2 bolt motor mount bolt pattern. Stock FE Comet/Fairlane and Mustang motor mount plates are designed for the 1965 and later blocks, that have 4 motor mount bolt holes.
Ctcobra
« Reply #2 on: June 04, 2019, 06:52:22 PM »
Thanks Rory! I am using the Crites installation kit for the early, pre 64 FEs to resolve the motor mount issue.
« Reply #3 on: June 04, 2019, 07:03:07 PM »
Hey  keep us informed on the project. ;) 8)
TimeWarpF100
« Reply #4 on: June 07, 2019, 05:14:55 PM »
Thanks!
Steve D
Keep us updated! Wish I had a '66 Comet . .
