Author Topic: 4" or 5" long 9" yoke ??  (Read 3220 times)
winr1
« on: June 02, 2019, 10:51:10 PM »
Any difference ??
Preferences ??
Ricky.
Re: 4" or 5" long 9" yoke ??
« Reply #1 on: June 07, 2019, 12:45:09 PM »
I usually use the short one but if the driveshaft is an inch short the long yoke works with no down sides that I can tell.
winr1
« Reply #2 on: June 07, 2019, 11:43:11 PM »
Thank you TomP :-)
Close to ordering parts for my 9" build
Ricky.
« Reply #3 on: June 11, 2019, 10:26:05 AM »
All my 9" builds use the short.  Have a couple of longs in the box, haven't found a use yet.  Short allows for same driveshaft in the Falcon and the 70 Mustang when switching from an 8" to a 9".
winr1
« Reply #4 on: June 11, 2019, 01:00:08 PM »
Thanks Chris :-)
Good to know, the ones I pulled from Slicks were all long with 1310/1 1/16" caps
3rd member I traded for has a 1330/ 1 1/8" caps, Dennys Driveshaft had a conversion u-joint
Also, I had to put the grease fitting towards the driveshaft
Installing towards the yoke would not allow room to be greased
Ricky.
