Author Topic: US Strange versus Motive ring and pinons question  (Read 3984 times)
winr1
« on: June 01, 2019, 04:05:20 PM »
https://www.strangeengineering.net/product-category/high-performance-street/9in-center-sections-components/ring-and-pinion-ford-9-inch-gears/
The US Strange pinions have an undercut where as the Motive do not ??
Any opinions on what brand ring and pinion to buy ??
The 4.00 looks like it would be just right for my plans
Ricky.
Re: US Strange versus Motive ring and pinons question
« Reply #1 on: June 01, 2019, 07:54:09 PM »
I would check this place out. I have ordered a couple gears from them. I asked and they are re-boxed Richmod Excel gears. 8620 steel. I always deburr every tooth and stone the back of the ring gear. I had a 4.33 that set up perfectly, had no noise, and after a few hard street miles and a couple passes at the track everything still looked perfect.
http://www.ebaystores.com/Quick-Performance-Racing/Ring-Pinions-Gears-/_i.html?_fsub=2&_sid=22645555&_trksid=p4634.c0.m322
« Reply #2 on: June 01, 2019, 08:15:41 PM »
As long as the undercut is equal to the groove root diameter of the splines there will be no difference in the twisting strength of the shaft.  But having the undercut might reduce/eliminate the possibility of stress risers propagating from the machined edges on the splines.
winr1
« Reply #3 on: June 01, 2019, 10:07:28 PM »
Thanks Jared, I will check them out :-)
Thanks Barry :-)
This would make my F100 jump ^_^ .... 9" Ford Lightweight 6.83 Gears Ring Pinion  ... lol
Ricky.
babybolt
« Reply #4 on: June 04, 2019, 07:30:44 AM »
Tom's Gear and US Gear are made in the US.
US Gear has some ring and pinions pre-broke in - at a cost of course.
winr1
Thank you babybolt :-)
« Reply #5 on: June 05, 2019, 06:41:54 PM »
Ricky.
gt350hr
« Reply #6 on: June 06, 2019, 11:10:01 AM »
   Ford pinions were undercut as well . Richmond began the no undercut style. In the 50+ years I have been doing Ford diffs , I have only seen ONE pinion break in the under cut area and it was from a crash , not torsional twisting. I broke it while trying to straighten it ( incorrectly in a press , in my early days).
    Randy
winr1
Thank you Randy :-)
« Reply #7 on: June 06, 2019, 04:39:32 PM »
Ricky.
