Author Topic: How thick are 427 screw in core plugs ??  (Read 4789 times)
winr1
« on: May 30, 2019, 07:27:28 PM »
I have 6 screw in core plugs, they are .836 thick
Are these correct for a 427 ??
Ricky.
CaptCobrajet
Re: How thick are 427 screw in core plugs ??
« Reply #1 on: June 07, 2019, 06:45:14 PM »
Originals are .500 deep.  6 threads on them.....As long as you don't bump the cylinders inside, it won't matter.
Blair Patrick
« Reply #2 on: June 07, 2019, 09:21:37 PM »
The big electrical type plugs will hang out the sides of the block  good bit and can interfere with the motor mounts.
We buy plugs in bulk and machine them on both front and back to get them closer to the OEM thickness
winr1
« Reply #3 on: June 07, 2019, 11:36:55 PM »
Thanks yall :-)
Looked a bit thick too me
Any want them free gratis ??
Ricky.
CaptCobrajet
« Reply #4 on: June 08, 2019, 09:47:48 AM »
I bought a second tap and cut it off sorta like it would be a "bottom" tap. We thread the hole a little deeper without hitting the cylinder core, so we can get a little past flush.  I got some brass recently somewhere that we're .750 thick.....square socket head, but they worked good.
Blair Patrick
« Reply #5 on: June 08, 2019, 07:07:58 PM »
I just installed some plugs on my own block last weekend. I got the ones from DSC that are .650" thick. They have a 3/4" hex drive. I have two taps and as Blair mentioned I cut one down about 1/4" shorter so I could use it as sort of a "bottoming" tap. I only needed the short tap for one hole, all the others threaded with the long tap without hitting a cylinder.
winr1
« Reply #6 on: June 08, 2019, 10:58:51 PM »
Thanks much guys :-)
Ricky.
« Reply #7 on: June 09, 2019, 12:44:40 AM »
I use Dennis's plugs on the race motors. Set them with epoxy,  then block fill. After everything has set and is good I dake a angle grinder with a grinding wheel and make them flush with the block for a nice neat custom look. I also have used the 1-1/2" brass clean out plugs on street engines.  A good flap sanding wheel on the angle grinder smoothed out the rough cast and makes them nice and purrrdy lol. Looks good with a nice painted Ford blue block .
« Reply #8 on: June 09, 2019, 09:42:54 PM »
Performance FE engines are black! ;) :)
winr1
« Reply #9 on: June 10, 2019, 06:55:36 PM »
Ricky.
« Reply #10 on: June 11, 2019, 04:57:38 PM »
Would bottoming against a cylinder be a bad thing or would it provide a little more strength?
« Reply #11 on: June 11, 2019, 06:22:05 PM »
It would distort the cylinder
