Author Topic: Edelbrock heads. Differences? #6005  (Read 4846 times)
67428GT500
« on: May 28, 2019, 05:25:20 PM »
I have called Edelbrock three times. They have me leave a return contact number and didn't call me in five days now. Is anyone familiar with this number? I presume they're decent heads?
        -Keith
Re: Edelbrock heads. Differences? #6005
« Reply #1 on: May 28, 2019, 05:44:35 PM »
16 bolt exhaust pattern,  little bit smaller combustion chamber, cj style heads. I have had my 6 double 0 five heads since early 2000's. They have been hand ported and massaged a few times then finally cnc'ed by kuntz back in 2016. 6005 is one of the first series of the edelbrock heads.
« Reply #2 on: May 28, 2019, 06:21:10 PM »
I have 6005 heads.  They are the 16 bolt "72cc" unmachined chamber head.
paulie
GerryP
« Reply #3 on: May 28, 2019, 06:32:15 PM »
Manufacturer sites can leave something to be desired. I went to Edelbrock's site and they do not have a comparison feature.
So, if you go to Summit's site, https://www.summitracing.com/ you can select the various heads and check the comparison box then see the actual differences.  The 6005 is just the basic medium riser configuration with a 16-bolt CJ flange and built with springs for a hydraulic roller cam.  The 6069 is the same head but has springs for a flat tappet cam.
Hope that helps.
67428GT500
« Reply #4 on: May 28, 2019, 06:52:27 PM »
I tried to cross reference the heads. I am guessing they are the same as the 60069 heads currently offered. 72CC chamber, 2.09 int, 1.66 exhaust wih CJ bolt pattern and 170CC runners.
