Author Topic: Two FE blocks  (Read 5363 times)
babybolt
Two FE blocks
« on: November 20, 2012, 08:56:46 AM »
Two FE blocks available for delivery to Columbus, one is a D2TE or D3TE with the 3 web mains, standard bore $225, and the other is a 63 or 64 block with the extra knorbs inside the pan rail for the crossbolts.  Date code is either 3C18 or 3G18, no other casting id's other than DIF.  Standard bore, $400.
Re: Two FE blocks
« Reply #1 on: November 20, 2012, 10:51:21 AM »
Doug, what is the bore size?  Are these 390 blocks?
babybolt
Re: Two FE blocks
« Reply #2 on: November 20, 2012, 12:47:25 PM »
Yes, 390 blocks, 4.05 bore.  I looked at the truck block this morning, it is a D4TE.
