Author Topic: Piston skirt to cylinder wall clearance?  (Read 3403 times)
fairlaniac
« on: May 16, 2019, 08:09:37 AM »
Is it per side or on the diameter? Say manufacturer says to have a .004 piston to wall clearance and bore is 4.230. Is the piston skirt diameter 4.226 or 4.222?
I ask because I don't know.
Thanks!
Doug
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Re: Piston skirt to cylinder wall clearance?
« Reply #1 on: May 16, 2019, 08:37:47 AM »
Per diameter.  A 4.230” finished bore size with a .004” piston/cylinder clearance would have a piston measuring 4.226”.
fairlaniac
« Reply #2 on: May 16, 2019, 09:03:10 AM »
Thanks Brent!
Doug Bender
1978 F150 2WD 390
gt350hr
« Reply #3 on: May 17, 2019, 12:14:31 PM »
      Doug ,
          Always follow the basic recommendation of THE piston manufacturer , don't "generalize." Each and every aftermarket maker has their own view on skirt turning and shaping . plus "where" they want you to measure them at. I fell victim to that about 20 years ago when I got a set of Venolia pistons by measuring and clearancing  them like a JE. They scuffed from lack of clearance. Engine ruined. Lesson learned.
   Randy
