Author Topic: I Did Something Wrong? Double Post Ended Up Here And In The Non FE Section  (Read 3070 times)
chris401
3.54 gears. Has resistance when you raise one wheel and turn it. The owner told me this was an F-100 Camper Special. Seems reasonable if the rear, shocks and NP435 are factory. Pictured are the numbers it has on the right rear tube. These are not any BOM numbers I could find on line. Anyone else know?
Thanks
« Last Edit: May 17, 2019, 10:57:06 AM by chris401 »
Re: Five Lug Dana 60, Which Locker Is It?
« Reply #1 on: May 07, 2019, 12:12:42 AM »
Years ago, I owned a 67 F100 with a 5 lug Dana 60,with 3.54 gears and a limited slip differential. It was a clutch style unit, I think it was called a "Power Lok" or something similar. Whatever it was called, it was a very good locking diff.
« Reply #2 on: May 13, 2019, 05:12:32 PM »
Yes. All those got the good 4 spider Powerlok. The whole reason for that Dana 60 was there wasn't a limited slip 9" in the trucks until later (70?)
