Author Topic: Valve keepers part number question  (Read 3848 times)
« on: May 04, 2019, 08:04:39 PM »
Some of you have access to parts catalogues that I do not have access to any more.  I am porting my personal cylinder heads for a 292 Y Block, and I have Ferrea 5/16" valves with conventional 7* lock grooves, and I have been trying to find a titanium retainer for use with beehive springs.  The beehive spring I used in my EMC engine last year worked perfectly with 11/32" stems and beehive springs (CC 29618-16).  Comp Cams 788-16 retainer, but it does not work with 5/16" stems, and Comp Cams suggests part number 762-16, but they don't furnish keepers or make them for 5/16" valves.  Do any of you have experience with the beehive/5/16" valves?  If so what part number do you use for locks and retainers.  I will buy 10*/7*/7* super locks if they will work.  Titanium would be better.  I also need a part number for 5/16" radial lock for a titanium retainer for same beehive spring for another set of heads.  Any ideas?  Thanks, Joe-JDC
« Last Edit: May 04, 2019, 08:18:18 PM by Joe-JDC »
winr1
Re: Valve keepers part number question
« Reply #1 on: May 04, 2019, 09:13:32 PM »
hey Joe :-)
I have no clue.. but .... am really interested in ya heads an the y block
Hope ya post a build and info thread when through
Ricky.
« Reply #2 on: May 05, 2019, 01:56:10 PM »
Let me ask this question another way.  Can I use a super 7* lock for 5/16" valve with a retainer for 11/32" valve spring?  Has anyone actually tried this?  I hate to buy locks and retainers just to experiment and have them sit because they are not returnable---especially titanium.  Joe-JDC
« Reply #3 on: May 05, 2019, 06:12:59 PM »
Joe, I use 5/16” stem valves with beehives all the time.  Shoot me an email with exactly what you have and I can help.
« Reply #4 on: May 05, 2019, 09:18:58 PM »
As mentioned above:  Comp Cams 26918-16 valve springs, Comp Cams 788-16 Titanium retainers, and I am changing to 5/16" valve stems with traditional lock grooves on one set of valves, and radial locks on another set of valves.  I need a set of titanium retainers, and preferably a set of titanium locks for the 26918-16 valve springs, and another set of titanium retainers and bead locks for the second set of heads with 5/16" valves.  Joe-JDC
« Reply #5 on: May 06, 2019, 05:33:47 AM »
Use the 788 retainers for both.  Use a PAC L8148 lock for the square groove and an L8150 for the bead lock groove.
I don't see the need for a titanium lock, but if your heart so desires, call Victory Valves for those.
« Reply #6 on: May 06, 2019, 08:58:06 AM »
Thanks,  I will check it out.  Just trying to save all the weight I can on valvetrain.  Joe-JDC
