Author Topic: Quality fuel pressure gauge  (Read 8680 times)
John67427
« on: May 03, 2019, 01:41:11 PM »
 Has  anyone found a decent fuel pressure gauge? I’ve had a Moroso then a Holley now a liquid filled Aeromotive. Looked at the Aeromotive today and the needle is at 4 lbs and will not go lower. Used the pressure relief valve since it is liquid filled and did not change I’m not a fan of liquid filled gauges but thought it may be a better quality and can relieve the pressure for accuracy. Aeromotive said they would replace it but looking for options as I have not had good luck so far.
Re: Quality fuel pressure gauge
« Reply #1 on: May 03, 2019, 01:56:01 PM »
I have two AutoMeter mechanical gauges in the methanol system for my ECTA car. One is mounted in the gauge panel at the driver's position, and one is right next to the Aeromotive pressure regulator in the engine compartment to make things easy when doing a pressure adjustment. Both gauges are about 12 years old and I've noticed no problems at all. Both return to zero.
« Reply #2 on: May 03, 2019, 02:41:34 PM »
Are you talking the small versions that mount on a regulator or fuel rail?   Never really had one to try.  My std size Autometer has been faithful for decades.  Though it was a filled gauge originally I drained it after finding out it changes readings with temperature changes.
John67427
« Reply #3 on: May 03, 2019, 03:05:13 PM »
Yes Larry, mounted just before Ford fuel log. Maybe just bad luck on my part....
gdaddy01
« Reply #4 on: May 03, 2019, 04:38:32 PM »
same problem here , been through three , none work .
ec164
« Reply #5 on: May 03, 2019, 05:22:56 PM »
John if you are interested I have a New Autometer 2 5/8 ultralight gauge in box part#4411, that I will sell for $50..               Al
You're ahead in a Mercury......all the way
« Reply #6 on: May 03, 2019, 06:07:38 PM »
I believe I have a new Autometer 2 5/8" Sport Comp. Black face IIRC. I will have to find it if you are interested.
John67427
« Reply #7 on: May 03, 2019, 07:41:37 PM »
Al and Jared,
  Thanks for the offers! Aeromotive is going to replace the one I have so I’ll give it one more try.
427Fastback
« Reply #8 on: May 03, 2019, 10:30:15 PM »
My 67 has a liquid filled gauge on the regulator.It has failed after 400 miles.It was a good quality one.Dale P has a box of leaky gauges and tells me to stay away from the liquid filled ones although I like them.They are very temperature sensitive and give you a different reading depending on the weather.I am going to just set the pressure with the new gauge and pull the gauge out..
1936 Diamond T 212BD
1990 Grizzly pick-up
John67427
« Reply #9 on: May 04, 2019, 10:49:59 AM »
Just spoke to Summit Racing and they are just sending a new one out, they don’t want the old one back which leads me to believe the new one isn’t going to last. Going to do what 427 Fastback did, set fuel pressure, pull it off and put a plug in the line
« Reply #10 on: May 04, 2019, 09:40:24 PM »
I'd re-think it. Pulling the gauge out after setting the pressure is not going to solve any problems. It is like doing away with an oil press. or water temp. gauge. You may not know you have a problem, till it's too late. One simple thing could cause a big problem. I like keeping an eye on my vitals, so I have all my gauges in the car. I used to have a mechanical fuel pressure gauge with an isolator mounted on the intake, but now I'm trying the electric to give a cleaner look and one less fluid filled line to worry about. JMO
Posi67
« Reply #11 on: May 04, 2019, 10:36:56 PM »
I chased fuel pressure problems for some time with a liquid gauge and tried several different regulators. Actually read on the old FE Forum about the liquid gauge issue and bought the plain one. Pressure was steady but they all leak in short order. A few weeks back at the local speed shop while buying a new (and soon to leak) gauge the counter guy said " lucky you didn't grab a liquid fill one... they are shit". Yeah, I know that so why do you have so many different ones for sale here????
I'm all for buying a "quality" gauge as soon as someone can verify such a thing is actually made.
John67427
« Reply #12 on: May 05, 2019, 05:30:22 AM »
I do like to keep an eye on all the vitals.... thank god the oil and water temp gauges work without issue!!!! Not having an issue with fuel pressure but it frustrates me to have a gauge that I know is not reading correctly. Every time I’ve replaced one my initial reading has been where I want it and have not had one leak yet just never go back to zero. I’m with Posi67 and at this time I don’t see that a quality gauge is made at this time  :(
« Reply #13 on: May 05, 2019, 08:33:56 AM »
I would recommend staying away from the liquid. We quit using them a long time ago. Only my opinion, but I would mount the gauge where you can see it while you are in the car. I know AutoMeter has a good reputation. They are made not far from me in Sycamore IL. I have used plenty of Autometer and had zero problems. I have three in my daily driver and have been in there for at least a couple years and they worked just fine this winter when the temp. was -34°F out. They functioned just fine. I am also a fan of the old Stewart Warner stuff. I see they are still making gauges, but not sure if they are they same quality they were:
https://www.stewartwarner.com
« Last Edit: May 05, 2019, 08:35:32 AM by Nightmist66 »
Posi67
« Reply #14 on: May 05, 2019, 09:56:28 PM »
Yup.. got a couple of the stuck needle ones as well. Figure they went bad before having a chance to leak. This was my last one and oddly, it only leaked internally.
