Author Topic: Hot days coming  (Read 9972 times)
Bolted to Floor
Re: Hot days coming
« Reply #15 on: May 01, 2019, 07:17:49 PM »
I’ve been thinking about a spacer too. I’m not wild about adding a bung to the RPM intake, but could live with it.
?? The RPM has two spots or do you need more?
Yes, I need more....I have a heater hose connected to one and the temp sensor for the factory gauge in the other. I want to add a temp gauge with numbers. I’m one of those guys that likes to see all the factory stuff operate!!
66FAIRLANE
  • Andy
Re: Hot days coming
« Reply #16 on: May 02, 2019, 06:39:22 AM »
Ahh of course. I don't have a heater. The floor gets hot enough!  ;D
Ranch
Re: Hot days coming
« Reply #17 on: May 02, 2019, 07:33:56 AM »
Ok , need the size of the big hole for your thermostat in your Manifold I have a C7 so need the newer dimension I really don't want to open it up till I need to. Thanks guys ,,,,Bill
Re: Hot days coming
« Reply #18 on: May 02, 2019, 08:38:11 AM »
No, not in Houston.  That would be a wet heat.  Been there, sweated that.
stubbie
Re: Hot days coming
« Reply #19 on: May 02, 2019, 06:40:05 PM »
Ranch
Re: Hot days coming
« Reply #20 on: May 02, 2019, 07:29:47 PM »
Not quite Stubbie Even that method was mentioned John and I were more into a spacer at the thermostat to get a more accurate Temp reading. We see Chebbies all over but non for FE's.
Thanks anyway: I did save that site just in case.
Re: Hot days coming
« Reply #21 on: May 03, 2019, 07:03:16 AM »
Didn’t this come up like a year ago and somebody made what you guys are talking about. Obviously I don’t know who it is but I’m having dejavu
Bolted to Floor
Re: Hot days coming
« Reply #22 on: May 03, 2019, 08:50:23 AM »
I was thinking the same thing but couldn’t find anything when I was searching.
C8OZ
Re: Hot days coming
« Reply #23 on: May 03, 2019, 09:32:28 AM »
I think I linked to this one in an earlier thread, as they're a lifesaver, but I don't know if this particular one is the port/thread size you need.
https://www.tascaparts.com/oem-parts/ford-hvac-elbow-connector-e5tz18599c?origin=pla&gclid=EAIaIQobChMI9JLxiaK03wIVEI7ICh0QUAZrEAQYASABEgJFT_D_BwE
The 18599 base number does come up with quite a few possibilities, though.
« Last Edit: May 03, 2019, 09:34:22 AM by C8OZ »
