Author Topic: Blair's 531 hp 390 with tweaks  (Read 4117 times)
70bosscat
« on: April 24, 2019, 07:24:12 PM »
Say you were to duplicate this build with the only changes being 50 more cubes, 15 more degrees duration @.050 and .060 more lift. What rpm do you think it would make peak power and torque and how much would it be?
chilly460
Re: Blair's 531 hp 390 with tweaks
« Reply #1 on: April 24, 2019, 09:14:01 PM »
Don’t have build in front of me, but it’d likely peak around 400-500rpm higher with that much more cam even with the added cubes.  Caveat being that the induction wasn’t a restriction.
WerbyFord
« Reply #2 on: April 24, 2019, 11:27:24 PM »
I don't have a 531hp Blair 390 either but I found this dyno from Blair:
Torq 504 at 4000
Powr 517 at 6000
Here is what the Gonkulator got (with a water pump)
Torq 505 at 4300
Powr 506 at 5800
Now add 15 degrees & .060" to the cam so 240 248 .570 .570 up to 255 263 .630 .630
Torq 501 at 4600   -4
Powr 532 at 6100 +26
Now 4.25 stroker to add 50cid
Torq 560 at 4500 +59
Powr 541 at 5900  +9
That would be my guess.
This build had iron 428cj heads so probably running out of air.
chilly460
« Reply #3 on: April 25, 2019, 08:07:58 AM »
Here it is Werby
http://fepower.net/simplemachinesforum/index.php?topic=4575.0
There was a TFS headed 462ci that Larry posted awhile back, 246* hydraulic roller peaked at 6200rpm, Blair posted an Edelbrock headed 471ci(?) that had 5800rpm peak with a 248* hydro roller.
« Last Edit: April 25, 2019, 08:20:38 AM by chilly460 »
