Author Topic: FE Reunion Driveshaft  (Read 3784 times)
2ndgear
« on: April 23, 2019, 09:01:59 AM »
What I have is a 45-1/2 inch. center to center 3 inch O.D driveshaft with a 6 inch 31 spline slip yoke. The shaft comes with 1330 u-joints on both ends along with the slip yoke attached. The shaft was out of a 69 mustang with a 4 speed. The 4 speed I had was a big in and big out with a long tail housing. 17 inch. verses a 14 inch. That is why the shaft is on the short side. I went with a gear vendor and 1350 u-joints and had a new shaft made. The shaft would work if you need to shorten it for a gear vendor or a set back engine. The shaft is in great shape and can bring to Beaver Springs. $75.00 for everything OBO
« Last Edit: April 23, 2019, 09:04:01 AM by 2ndgear »
Re: FE Reunion Driveshaft
« Reply #1 on: April 23, 2019, 09:40:46 AM »
Dan, I was going to text you and see if you were going to make it this year. Glad to hear you're going. I have a few questions for you about your GV installation when I see you there.
2ndgear
« Reply #2 on: April 23, 2019, 06:33:10 PM »
Yes Doug
We will be in town late Thur. (12-1/2 hours) and at the track Fri. morning.  See you and Trish then. Travel safe.
Dan
