Author Topic: Drilling Clutch Fork for Spring Clip  (Read 2858 times)
urchinhead
« on: April 10, 2019, 10:28:23 AM »
Does anyone know what size the 2 holes need to be and how critical the locations are for modifying a clutch fork to use the earlier style bellhousing pivot? I have an early 428/390GT bracket, and am planning to leave the bracket and modify the fork. I drilled out the rivets and removed the clip that is for the later style pivot bracket, and was planning to drill the fork clip holes today.
« Last Edit: April 10, 2019, 11:15:48 AM by urchinhead »
1964 Galaxie 500 Convertible, drivetrain on stand
1970 F100 Custom, 428 - body work and paint in progress
babybolt
Re: Drilling Clutch Fork for Spring Clip
« Reply #1 on: April 10, 2019, 06:36:43 PM »
Would do just the opposite, leave the spring clip on the fork and change out the pivot on the bell housing for the later design.
urchinhead
« Reply #2 on: April 10, 2019, 07:27:37 PM »
That was my first thought, but solution 2 will get this done faster. I already removed the riveted plate and the spring clip should be here tomorrow.
