Author Topic: Felpro intake gasket  (Read 5842 times)
Saltshaker
« on: April 09, 2019, 07:59:58 AM »
LR heads and RPM intake?
Jon
KMcCullah
Re: Felpro intake gasket
« Reply #1 on: April 09, 2019, 09:32:03 AM »
I like the Felpro MS90145 for iron heads.
Kevin McCullah
« Reply #2 on: April 09, 2019, 01:17:08 PM »
I agree, low riser 2x4 intake with iron heads and with survival heads.
Just switched to a gasket that I got through Barry when I switched to BT 2x4 intake.
67428GT500
« Reply #3 on: April 11, 2019, 12:18:21 AM »
The 90145 aren't a good choice. They also don't compress well. Low Riser port is 1246-S3. Those have the shim steel center.
        -Keith
blu64galaxie
« Reply #4 on: April 11, 2019, 10:08:20 AM »
x2 on the 1246-S3's  ....albeit, after 2 cruise seasons of running those, I noticed some squirming developing .....when I changed out my iron heads for Ed's last spring.
Also, if this is your first time mounting an RPM intake on iron heads, dry fit the intake first, with gaskets ...then measure 'china wall' gap to see if you have room for the end seals --or not. .......Don't do like I did, ....and wind up crop dusting the neighborhood on the first test drive, lol.
Norm
Norm Russo  blu64galaxie
1964 Galaxie 500  aka 'the blue goose'
« Reply #5 on: April 11, 2019, 07:10:31 PM »
Sorry mixed up the numbers the 1246s are the one never had a problem. ::)
67428GT500
« Reply #6 on: April 11, 2019, 10:30:00 PM »
The 1246 is the printo seal we all had issues with. The 1246 S3 was the improved with the shim. These are for the tall port/low riser configuration.  Barry Robotnic's brain child.   -Keith
« Reply #7 on: April 12, 2019, 12:06:02 AM »
I dunno, I still like the regular MS90145's They compress enough to do the job.
67428GT500
« Reply #8 on: April 12, 2019, 02:25:58 AM »
They may be fine with iron, not with aluminum.
« Reply #9 on: April 14, 2019, 06:31:44 AM »
I have never had an issue with the blue Felpro, aluminum or iron. Could you have had surface alignment issues? In fact I wish they made a med riser version
6667fan
  • Every Second Counts
« Reply #10 on: April 14, 2019, 09:06:05 AM »
I believe the 1247-S3 is for medium riser ports. If it has an S then it is reinforced.
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
67428GT500
« Reply #11 on: April 18, 2019, 10:34:19 PM »
Yes. 1246-S3 is Low Riser ports. 1247-S3 Med Riser ports.
