Author Topic: Distributor total mechanical advance  (Read 28445 times)
amdscooter
« on: November 09, 2012, 04:23:08 PM »
Looking for a lil help here. My 390 from this thread http://fepower.net/simplemachinesforum/index.php?topic=578.0 is finally back together and old timing issues are coming back to haunt me. Relevant specs:
390 Fe .030 over bottom end stock.
fresh heads hardened exh seats.
Comp 268H cam and matched springs
Holley 625 carb
Edelbrock streetmaster intake
FPA headers w/Magnaflow 2.5" exh.
I'm using a re-manufactured Cardone distributor with a vac cannister and have replaced the points with a Petronix FF2 setup. Then options on my reluctor arm for total mechanical advance are 14L and 18L. With the reluctor set on 14L I need to keep my initial timing at 8 degrees or under to stay under 36 total mechanical advance. My new build hates 8 degrees initial and really likes closer to 15 degrees initial much better. But that amount of initial blows my total mechanical advance budget to hell and back. I've looked high and low for a stock 8L~10L reluctor arm.. no dice. I'm beginning to believe they really do not exist.  ::) I'd really like to avoid taking the breaker plate out and having the slots welded and ground to reduce total advance as it's money I'd rather not dump into this particular distributor if at all possible. I've tried putting some rubber hose over the pin to restrict total mechanical with limited success.. it's kinda wonky and not at all consistent. Sooo.. Is there a distributor on the market that has a wide range of reluctor plates readily available? I would not mind putting a HEI in to be honest and this would be as good as an excuse as any to get one. Any better options and opinions welcome.
thanks
scott
Chad D
Re: Distributor total mechanical advance
« Reply #1 on: November 09, 2012, 05:03:12 PM »
« Reply #2 on: November 09, 2012, 05:36:05 PM »
Instead of rubber tubing you can try heat shrink tubing. You need to build it up in layers, in other words put a piece on, shrink it, put another piece over it, shrink it. Keep repeating. You'll need various sizes of the tubing as it gets thicker. It will be more firm than the rubber tubing and easier to build up to the amount of limit you need.
bartlett
« Reply #3 on: November 09, 2012, 05:55:43 PM »
MSD 8595 ...
I like mine alot... very nice.  It comes with a recurve kit to set it anyway you like. It also has a built in rev limiter. No box needed ect ..
The problem, Lots of $$  and you will need plug wires to boot...
No way I would go HEI .... Thats GM voodoo    >:(
amdscooter
« Reply #4 on: November 09, 2012, 07:45:22 PM »
MSD looks like a great setup.. just beyond my budget at this point. That's why I was looking at the HEI.. they run about $150 with plug wires but I have not been able to find any information on how the total advance is adjusted (if at all) on them.
thatdarncat: thanks for the suggestion but if at all possible I'd like to be done trying to add width to the post.
bartlett
« Reply #5 on: November 10, 2012, 02:39:46 AM »
amd I guess if money is tight,your going to need to figure out how to limmit advance on your dizzy.. cant be that hard  ::)
rockhouse66
« Reply #6 on: November 10, 2012, 06:41:52 AM »
I limit mine by silver soldering a (crude) bent piece of metal that I hook around the end of the slot.  I would work on the 18 degree side, measure the difference between the 18 and 14 degree slot to determine how much travel equals 4 degrees and then position the piece of metal where it will get you where you want to be.  I never had any luck with sleeving the post either.
You can also usually find a used Mallory Unilite for not too much money and they are adjustable for total advance.
Jim
« Reply #7 on: November 10, 2012, 07:54:57 AM »
Probably the cheapest way is to weld it.
You must have access to a mig or buzz box.
It's just a small tack and file job.
amdscooter
« Reply #8 on: November 10, 2012, 12:03:44 PM »
Mig/buzz box "access" to me = a trip to my local $75 guy. Meaning the local machining and welding guy up the street who seems to charge me $75 no matter what the job.  ;D
runthatjunk
« Reply #9 on: November 10, 2012, 02:26:44 PM »
If no welder available then JBWeld a chunk of metal on that slot.  As long as surface is clean and roughed up it will hold exceptionally well
1965 390 Galaxie 4 Speed
1966 428 Thunderbird
JimNolan
« Reply #10 on: November 10, 2012, 10:34:04 PM »
amdscooter,
    I'm getting ready to put the same combination together that you've got except this is a 410ci FE. Can I ask you what vacuum you are pulling at 14 degrees initial timing on that setup with the 268H cam and what rpm. Also, is there very much lope.
    As far as welding the mechanical advance, that's easier than you think. I do it every time I change the timing very much. Takes about 30 minutes to take it out, weld it, grind and file it and use measurements they give for advance you want. And, the measurements are right on. Jim
amdscooter
« Reply #11 on: November 10, 2012, 11:17:53 PM »
amdscooter,
Hi Jim, I'll get those readings for you tomorrow if I can locate my VAC gauge. Just re-sealed the passenger side valve cover and I'm going to let the goo cure overnight. As for lope.. there is barely any. With the headers and Magnaflow's it simply has a nice throaty rumble idling between 800~1k rpm. I'll post up a video if it's running tomorrow and not raining.
As for the mech. advance, thanks for the advise. I'm going to have a buddy over this week to get a second set of eyes on the tune. I might be missing something simple here and I wanna make sure before I tear into the distributor again.
FirstEliminator
« Reply #12 on: November 11, 2012, 03:04:13 AM »
   I wrote a post on a thread called "rotor phasing video". This is my prefered way to adjust mechanical range in a Ford distributor. Here is the link to the thread:
http://fepower.net/simplemachinesforum/index.php?topic=308.msg2283#msg2283
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
amdscooter
« Reply #13 on: November 11, 2012, 12:08:53 PM »
Interesting post. With a link of chain keeping the spring from stretching, how do you get any advance at all? I must be missing something..  ???
amdscooter
« Reply #14 on: November 11, 2012, 04:57:40 PM »
Hey Jim.. here is that video. 15 degrees initial at bout 900rpm.
http://youtu.be/olhXxOS43lw
Could not locate my vaccum gauge. I'll get that info for you as soon as I find it.
