Author Topic: Valve Springs  (Read 8003 times)
JimNolan
Valve Springs
« on: November 06, 2012, 03:27:36 PM »
Guys,
   I've got a question. I had a Comp Cam Kit that came with #426 valve springs. The collapsed height would give me 317 lbs spring pressure and they are already installed on the heads I'm going to use. I decided to go with a different Comp Cam with the same lift but that cam says to use a #940 valve spring that would deliver 213 lbs collapsed pressure. Both these valves have about the same installed height and both coil bind heights are far from causing a problem. Lift is less than .500" on either cam.
  Is there any reason for me not to use the 33% heavier spring with the cam that says it should have a 33% lighter spring. Jim  Thanks
Re: Valve Springs
« Reply #1 on: November 06, 2012, 05:53:24 PM »
In my opinion there is no reason not to use your existing springs.  I think they will work fine - Jay
JimNolan
Re: Valve Springs
« Reply #2 on: November 06, 2012, 06:05:34 PM »
Thank you Jay. Appreciate that. Jim
jimeast
Re: Valve Springs
« Reply #3 on: November 09, 2012, 06:49:15 AM »
Is the spring a single or a double?  I'm curious what the cutoff in spring pressure is to dictate break in with the inner spring removed, or if the spring is a single, doing break in with a wimpier spring?
Note: I'm assuming a flat tappet, your cam maybe a roller.
JimNolan
Re: Valve Springs
« Reply #4 on: November 09, 2012, 07:32:39 AM »
jimeast,
   It's a spring with a flat type inner spring that I think they call a dampner. From the measurements it shows that the installed pressure with the new spring is within 15 lbs/in and when the spring is collapsed at my lobe lift it's only 70 lbs/in difference to the plus side. I don't understand how an XE265 (smaller cam) would have heavier springs than a 268H cam. It's not like the 268H cam is made from aluminum and can't use a heavier spring. Jim
rockhouse66
Re: Valve Springs
« Reply #5 on: November 09, 2012, 07:51:19 AM »
I am guessing that XE has a much more aggressive ramp.  I think it is one of those assymetric grinds and you can actually see the difference in lobe shape on the opening/closing ramps with the opening ramp being pretty steep.  Comp probably doesn't want to leave the valve behind when the cam goes over the top of the lobe.
Jim
Re: Valve Springs
« Reply #6 on: November 09, 2012, 08:21:36 AM »
Just as a rule of thumb, I think if you are running more than about 175 pounds on the seat or 350 pounds open, you should swap out the springs to lighter weight ones for break-in.  There are lots of different opinions on that, but those are the numbers I go by.
Re: Valve Springs
« Reply #7 on: November 09, 2012, 07:04:41 PM »
I agree with the idea of using the lighter springs for break-in as with today's lifter/heat treat/oil issues it's way too easy to flatten a flat tappet cam lobe (or three!). 'Course, with a roller or hydro roller this issue becomes moot.
JimNolan
Re: Valve Springs
« Reply #8 on: November 11, 2012, 09:22:19 PM »
The 268H Cam with a perfect 1.900" Installed Ht. and a 940 spring calls for  93 lb/ft. with valve closed and 213 lb/ft with valve fully open. There is .200" left over before coil bind of 1.400".
The XE265 Cam with a perfect 1.800" Installed Ht. and a 926 spring calls for 109 lb/ft with valve closed and 317 lb/ft with valve fully open. There is .170" left over before coil bind of 1.140".
What I have with 1.850" Installed Ht. and a 926 spring is 88 lb/ft with valve closed and 317 lb/ft with valve fully open. There is .210" left over before coil bind of 1.140".
I can change springs if need be. I can't get hold of Comp Cams, they don't respond. So, give me a yes / no answer guys. Thanks, You guys probably have more experience than the guy that won't answer me at comp cams anyway. Jim
