Author Topic: Fuel Pressure Regulator Ideas  (Read 2895 times)
« on: February 28, 2019, 11:18:34 AM »
I've been dreaming up some ideas for the fuel line between fuel pump and carb for my '62. I ran into this style of regulator and wondered if anybody has any experience with them? The manufacturer is Malpassi. Looks like they are typically used for VW's and some other Italian brands.
Was thinking I would mount it in the same position a fuel filter canister for a 2x4 or 3x2 setup. I'm just not sure if this thing will flow enough? I can't find any flow ratings on them. They sell them with 6AN fittings, which is the line size I was targeting.
If you know of a similar style fuel pressure regulator let me know.
https://www.ebay.com/itm/MALPASSI-HIGH-FLOW-V8-FILTER-KING-FUEL-PRESSURE-REGULATOR-1-8NPT-FITTINGS-BDT/122794404108?epid=10008774200&hash=item1c971de90c:g:afEAAOSwjDZYb4U~:rk:10:pf:0
« Last Edit: February 28, 2019, 11:40:51 AM by mbrunson427 »
Re: Fuel Pressure Regulator Ideas
« Reply #1 on: March 01, 2019, 03:04:21 AM »
I have used them on Volvos with dual webers
they work verry good in that aplication
