Author Topic: 7.3 Or 460 ZF To 61-68 MEL?  (Read 3789 times)
chris401
« on: February 27, 2019, 08:23:47 PM »
Anyone have a Ford 460 or 7.3 ZF and a 61-68 MEL laying around? Pictures?
http://ford-mel-engine.com/viewtopic.php?f=52&t=1653&sid=612a2902209f1257636de7ba05ee492d
RustyCrankshaft
Re: 7.3 Or 460 ZF To 61-68 MEL?
« Reply #1 on: February 28, 2019, 08:35:08 AM »
Keep in mind that the 7.3 and BB patterns are close but not identical. Takes a little grinding to make a 7.3 trans work on a BB, so if you need an adapter plate keep that in mind. Have no idea on a MEL.
FrozenMerc
« Reply #2 on: February 28, 2019, 01:30:33 PM »
This thread does a good job of explaining the MEL bolt pattern changes throughout its run, including the dual pattern 460's that were used in 68-70.
http://ford-mel-engine.com/viewtopic.php?t=445
« Last Edit: February 28, 2019, 01:46:41 PM by FrozenMerc »
chris401
« Reply #3 on: February 28, 2019, 01:33:06 PM »
Yeah that was in the MEL link.
I am tempted to borrow a ZF case just to see how close it is. The cast iron FE bell didn't  work out. Turns out I am better with a grinder than cast iron welding.
chris401
« Reply #4 on: February 28, 2019, 01:40:10 PM »
Look at the 61-68  and you'll see it looks close.
babybolt
« Reply #5 on: February 28, 2019, 08:56:31 PM »
One weird thing is that Ford continued to cast 460 blocks with the extra two bolt holes for the MEL trans until the end of production.  And the aftermarket blocks like the A460 and Eliminator had the same bolt holes even though no one knew what they were for and the late MEL C6's are very rare.
You could get a 460 ZF5 trans instead of the 7.3L.
