Author Topic: Anyone know the width of the V-10 connecting rod? Same as 5.4 3v, but ???  (Read 4673 times)
Trying to find an inexpensive long rod for a build.  I have googled that but found nothing.  Anyone?  Joe-JDC
Re: Anyone know the width of the V-10 connecting rod? Same as 5.4 3v, but ???
« Reply #2 on: February 08, 2019, 10:41:55 PM »
Yes, that is why I need to know what the big end rod width is.  If it is already too narrow, then they will not work.  Also, if too wide they wont work for my possible project.  I can't afford that kind of money just to have them not work for me.  Joe-JDC
« Reply #3 on: February 08, 2019, 10:46:59 PM »
It says the big end width is 0.940" in the ad.   Is that not what you are looking for?
« Reply #4 on: February 08, 2019, 10:59:09 PM »
« Last Edit: February 09, 2019, 12:11:11 AM by fekbmax »
« Reply #5 on: February 08, 2019, 11:37:37 PM »
Nope, that's sbc size.  I am trying to find out the actual width of a Ford rod, not aftermarket.  Thanks, Joe-JDC
« Reply #6 on: February 09, 2019, 06:40:32 AM »
Big end width is .940".  Little end width is .965".
The big end is basically SBC size.  I'm doing a 4.6L 4V right now and I'm using an offset ground factory crankshaft, ground down to small journal SBC rod journals so I can use a Molnar 6" SBC rod.
Also, I wouldn't worry about the big end being too narrow.   If you're having custom pistons made, you can set it up like a piston-guided rod.
« Reply #7 on: February 09, 2019, 12:11:47 PM »
Thanks.  I am trying to find a 6.500", 6.400", 6.300" rod with the 2.000" rod journal, also. The price I was quoted for one of those lengths was $2200.00 for 8.  I can find 6.250", so that may be what I have to settle for.    I can't use the Honda or Mitsubishi rod journal on this particular build.  I was considering that V-10 rod because it is the length that would fit another build.  Being retired, I am finally starting several projects that have been on the back burner for a while.  It is fun, but expensive.  LOL   Joe-JDC
CaptCobrajet
« Reply #8 on: February 09, 2019, 12:30:33 PM »
Sent you a PM Mr.Joe...........
Blair Patrick
